Re: 440 pistons.
[Re: mayhem148]
#377850
07/17/09 12:47 AM
07/17/09 12:47 AM
RapidRobert
77(or 8) would be cast but eyeball the dampener(tapered is cast) & check the flat ID pad by the dist(note the letter) & the casting #'s on the side of the block(I forget which side). Cant help on the best piston source. I would suggest sonic checking to start off w a good foundation, nothing can be taken for granted
Re: 440 pistons.
[Re: mayhem148]
#377853
07/17/09 10:46 AM
07/17/09 10:46 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I run Ross forged in my 440.The 12.5 domes had 516s now Stealths.Its run on the street.Diamond also has good pistons.Those twu are probally the lightest made.Mine have been in for 10 years with no problems.Rocky
Chrysler Firepower
Re: 440 pistons.
[Re: RUNCHARGER]
#377856
07/17/09 01:49 PM
07/17/09 01:49 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I would say Ross, I hope you plan on makeing this a track "only" build, because in no time you'll hate haveing to run race fuel in it all the time, you really should have a "plan" of what you want, with compression like that, a big cam is the way to go, otherwize you'll regret it, if you have the funds, i'd go with a flat top & closed chambered aluminum heads, then go for a good quench, this way you can run on pump gas with 10.5-11.1 compression, just pick a cam that will get the cranking pressure where it needs to be for the octane & overall best power, so plan it out, just don't start throwing parts at it.
