Turn Signal starts normal slows fast #377653
07/16/09 09:39 PM
07/16/09 09:39 PM
72greencuda Offline OP
Is my turn signal switch toast or is this a deeper problem.
Re: Turn Signal starts normal slows fast [Re: 72greencuda] #377654
07/16/09 09:41 PM
07/16/09 09:41 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Increase your idle to 1000 rpms see if it still lags.
Your alt pulley could be the wrong diameter.
Re: Turn Signal starts normal slows fast [Re: mark7171] #377655
07/16/09 09:45 PM
07/16/09 09:45 PM
I'll try it tommorow
Re: Turn Signal starts normal slows fast [Re: mark7171] #377656
07/16/09 09:46 PM
07/16/09 09:46 PM
as said if it's not a low voltage at idle problem R&R the flasher can
Re: Turn Signal starts normal slows fast [Re: RapidRobert] #377657
07/16/09 09:52 PM
07/16/09 09:52 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
missed the beginnings. my bad.
Re: Turn Signal starts normal slows fast [Re: mark7171] #377658
07/16/09 10:07 PM
07/16/09 10:07 PM
Sounds like a flasher problem, to me
