Re: Hologen headlamp conversion [Re: Dougsmopars] #377425
07/18/09 05:01 PM
07/18/09 05:01 PM
cataclysm80 Offline
cataclysm80  Offline
Sounds nice. Where do you get the relay kit? Does Hella sell it also, or does it come with the lights?
Tav
Re: Hologen headlamp conversion [Re: cataclysm80] #377426
07/18/09 06:01 PM
07/18/09 06:01 PM
IA
landon1 Offline
landon1  Offline
IA
i wired-up my own with relays and fuses from radio shack for about $15 (i have wire already) for use with the halogen sealed beams in my car...or you can spend about $100 for a harness already made
'71 Satellite Sebring 440
Re: Hologen headlamp conversion [Re: cataclysm80] #377427
07/18/09 09:40 PM
07/18/09 09:40 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Tav
I bought mine with my Hella conversion lamps from www.rallylights.com
Here's some info: http://www.rallylights.com/hella/HeadlampWiring.aspx
Re: Hologen headlamp conversion [Re: In_The_Pink] #377428
07/18/09 10:32 PM
07/18/09 10:32 PM
dark side of the moon
Dougsmopars Offline OP
I got the conversion head light wire harness with relays from Painless. It's all plug and play.
Re: Hologen headlamp conversion [Re: Dougsmopars] #377429
07/19/09 11:16 AM
07/19/09 11:16 AM
SE Pa.
LimeliteAero Offline
SE Pa.
for the guys who have done the conversion, How did you get your power to the relays? I want to maintain as close to factory look as I can. I want to conceal the conversion as much as possible.
the paionless site says to gain power from the battery. How is that done? right from the battery or not?
TIA!
Re: Hologen headlamp conversion [Re: LimeliteAero] #377430
07/19/09 11:49 AM
07/19/09 11:49 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Easy power tap would be the starter relay.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Hologen headlamp conversion [Re: LimeliteAero] #377431
07/19/09 12:08 PM
07/19/09 12:08 PM
the house on the left.
cogen80 Offline
cogen80  Offline
TIA!
if ya want it to look stock as possible i would hide the relays under the battery tray and just get main power from the starter relay
Re: Hologen headlamp conversion [Re: In_The_Pink] #377432
07/19/09 12:16 PM
07/19/09 12:16 PM
cogen80 Offline
cogen80  Offline
I checked out that link. Didn't find any info on light patterns. I'm looking for a brighter, whiter light. And yes i know there different.
Look here: http://www.rallylights.com/hella/Beams.aspx
Orignal question was who makes a good conversion headlamp.
Hella makes an excellent conversion headlamp. I've used Hella E-code conversion lamps on three of my vehicles which previously used sealed beam halogen bulbs and highly recommend them to everyone.
are these the lights your talking about?
http://www.autobahnpower.com/products.asp?recnumber=422
Re: Hologen headlamp conversion [Re: cogen80] #377433
07/19/09 12:52 PM
07/19/09 12:52 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Looks like the same ones I just bought for my car. Did not install them yet.
Re: Hologen headlamp conversion [Re: 500Stroker] #377434
07/19/09 12:58 PM
07/19/09 12:58 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I just got done with this but wasn't concerned with looking stock. just wanted good quality stuff that I wouldn't have to mess with. I did it in a way where I could uninstall it in about 15 minutes and simply plug my stock stuff back in.
btw, wire size is not an issue with the existing stock setup. 16g feeds the lights. the real issue is all that resistance because the factory didn't use relays and old wiring. look at newer cars...my 99 grand prix uses 16g for the lights.
Re: Hologen headlamp conversion [Re: Pool Fixer] #377435
07/19/09 12:59 PM
07/19/09 12:59 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
another...
Re: Hologen headlamp conversion [Re: LimeliteAero] #377436
07/19/09 03:11 PM
07/19/09 03:11 PM
Shoreline, Washington
72roadrunnergtx Offline
Starter relay works just fine.
Looks correct for the 7" (2 headlight) Hella E-code version in discussion here.
Keep in mind wire has voltage drop, the higher the current the more voltage drop for a given wire diameter per foot. A four headlamp Hella system with standard sized bulbs(2 55/60 watt H4s and 2 60watt H1s), on high beam will pull about 17amps of total current, considerably less voltage drop on a 12ga wire than on a 16ga.
H4 and H1 bulbs are available in wattages that will simply melt 16 gauge wiring.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Hologen headlamp conversion [Re: cogen80] #377437
07/19/09 03:52 PM
07/19/09 03:52 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Yes they are.
Re: Hologen headlamp conversion [Re: 72roadrunnergtx] #377438
07/19/09 04:22 PM
07/19/09 04:22 PM
cataclysm80 Offline
cataclysm80  Offline
Yikes!
What gauge wire would you recommend, or what wattage should we limit ourselves to if keeping the 16 gauge wire? Would keeping the 16 gauge wire defeat the purpose?
Tav
Re: Hologen headlamp conversion [Re: cataclysm80] #377439
07/19/09 05:14 PM
07/19/09 05:14 PM
IMO, 12ga. minimum on the secondary side of the relays.
Defeat the purpose? Even if you stick with the 16ga wiring the relays are a must for this conversion.
From a previous thread on this subject,
"The sealed beam headlamps used on these cars originally were at best 15-20watts. On a four headlamp car, that is about 3amps for the low beams and roughly 8 amps on all four high beams. All this current passes through the headlight switch, dimmer switch, and the bulkhead connector using 16ga. wiring. Upgrading to a four lamp system with 55/60 watt low beam H4s and 55 watt H1 high beams will bring that current draw to about 8amps on low beam and upwards of 17amps with all four high beams burning. The original 40-yearold switches, wiring and connectors will not last long at that rate. Do yourself a favor and install the relays and run at least 12ga. wires on the secondary side."
Re: Hologen headlamp conversion [Re: 72roadrunnergtx] #377440
07/19/09 05:49 PM
07/19/09 05:49 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I use the 60/55W H4 bulbs and IMHO, they are plenty bright with great visibility. I don't do much driving with my high beams on, so that may be more of a factor for others.
Re: Hologen headlamp conversion [Re: cogen80] #377441
07/19/09 06:20 PM
07/19/09 06:20 PM
No those are 7 inch. My 68 is 5 something inches. But they look like that
Re: Hologen headlamp conversion [Re: Dougsmopars] #377442
07/19/09 06:25 PM
07/19/09 06:25 PM
With the painless conversion wireharness you don't use your stock lamp wiring. You plug one of your stock lamp plugs into there harness. It will only act as the trigger for the relay. They supply the wiring for your 4 head lamps. Just unplug your stock harness and let it sit there.
Re: Hologen headlamp conversion [Re: Dougsmopars] #377443
08/25/09 01:17 PM
08/25/09 01:17 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Stupid question. But on a 4 headlight system (71 Cuda')- do you have to have a relay for each light, or can you run 2 off of 1 relay? Thanks
Re: Hologen headlamp conversion [Re: Kirby] #377444
08/25/09 01:36 PM
08/25/09 01:36 PM
Two relays, one for the low beam circuit and one for the high beams (all four).
