convert 3310 vac secondary to mechanical?
#376818
07/15/09 11:27 PM
07/15/09 11:27 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
what's the pros and cons to doing the screw in the linkage trick tp convert your vacuum secondarys to mechanical ones on a race only application?
4bbl
If you can't hear it coming what's the point.......
Re: convert 3310 vac secondary to mechanical?
[Re: 4bbl]
#376819
07/15/09 11:42 PM
07/15/09 11:42 PM
Posts: 1,996 s. e. pa.
calrobb2000
s. e. pa.
hi good idea if you want to go slower ! if you want a mech secondary use a 750 double pump carb . list 4779
[Re: MNobody]
#376822
07/16/09 01:24 AM
07/16/09 01:24 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
the engine will have one big bog...no acelerator pump to cover the lean condition as the secondaries are throw open...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
