Question on 1967 B body rear end width vs. 68-70 #376814
07/15/09 11:23 PM
07/15/09 11:23 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
I understand the 66-67 B body 8 3/4 rear ends are slightly narrower than the 68-70 ones.
Is the distance between the spring pad to the back of the drum backing plate the same or is that where it is shorter?
Re: Question on 1967 B body rear end width vs. 68-70 [Re: KillerBee] #376815
07/16/09 12:00 AM
07/16/09 12:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's shorter in overall width , perch to perch dimension is the same so yes it's the distance from the pad to the end flange
Re: Question on 1967 B body rear end width vs. 68-70 [Re: JohnRR] #376816
07/16/09 01:10 AM
07/16/09 01:10 AM
N.E. Ohio
K
K
N.E. Ohio
Thanks John.
That will make a difference in correct rim backspacing when I play stuff the tire under the wife's Challenger.
Re: Question on 1967 B body rear end width vs. 68-70 [Re: KillerBee] #376817
07/16/09 08:26 AM
07/16/09 08:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks John.
Yes it will. Good luck ...
