Rocker shaft shimmimg
#376765
07/15/09 10:46 PM
07/15/09 10:46 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Is there different rocker shaft shims available, and if so- are there ones to stay away from and certain ones to stick with? I see some look like a simple washer, I would have thought Mopar rocker shaft shims would be rectangular with a hole in the middle, but since I've never even seen them in person what do I know...? It's for a big block if that matters, I am pretty sure I will need some so I want to have some on hand, I shaved my heads .030 and I'm using a .040 head gasket...
CrAzYMoPaRGuY
Re: Rocker shaft shimmimg
[Re: poison_ivy]
#376769
07/15/09 11:29 PM
07/15/09 11:29 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Actually shims will correct inproper rocker geometry. I have .090 under my shafts.
Rocker geometry doesn't change with head milling. Pushrod geometry does. Valve contact pattern will not change with head milling. If you have to shim the shafts there are other issues at work, i.e. long valves or sunken seats.
[Re: CrAzYMoPaRGuY]
#376770
07/15/09 11:56 PM
07/15/09 11:56 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Do you have a rocker to valve tip contact problem ?
[Re: JohnRR]
#376771
07/16/09 12:29 AM
07/16/09 12:29 AM
CrAzYMoPaRGuY
Canada
Nope. My pushrods are probably down into the lifter about .010" more than they should be, the steel shim gaskets were .020"ish, the Felpro gaskets are .040"ish, and the heads were cut .030", which makes me think my heads are down .010" from stock. I would figure a .010" shim would restore what I had, but when I check I want to have an assortment of shims to correct the lifter preload to where it SHOULD be....
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#376774
07/16/09 01:02 AM
07/16/09 01:02 AM
RapidRobert
I'm learning on this also & from what I gather(so far)you want to have the correct length pushrods(for milling/thick/thin gaskets or a factory stack of heck height tolerances) then check the wipe pattern & adj w shims(or deepening the rocker stand saddles in rare cases and guys have used soft copper washers as shims(just check/bevel the ones(s)on the oiling pedestal so they dont impede flow & have had zero problems.
[Re: RapidRobert]
#376775
07/16/09 01:21 AM
07/16/09 01:21 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
FWIW the amount your shimming shouldn't be a problem...Mancini sells them... http://chucker54.stores.yahoo.net/rocshafshim1.htmlOne of the reasons shimming can be a problem is it effects rocker geometry the picture attached will do more to explain that than I can... Another problem with shimming is people have split rocker stands by using them wrong...
[Re: 1_WILD_RT]
#376776
07/16/09 01:34 AM
07/16/09 01:34 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Dont mean to high-jack,got the same deal goin on with a 383.My 346 heads are cut .030 and have a .020 steel gaskets. I have a set of adjustable rockers sitting around,can I use those to correct things and make lifter pre-load right?
'71 383HP FJ6 Charger SE
[Re: 71 FJ6 Charger]
#376777
07/16/09 01:43 AM
07/16/09 01:43 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Dont mean to high-jack,got the same deal goin on with a 383.My 346 heads are cut .050 and have a .021 steel gaskets. I have a set of adjustable rockers sitting around,can I use those to correct things and make lifter pre-load right?
You need to consider custom length pushrods... Typically you want to wind up with two threads showing on the bottom of the adjuster screws... How is the contact between the rockers & valve tips? They should be shimmed side to side to center them on the rocker tips & the rocker pad should be centered to slightly outside of center on the valve stem with the valves closed...
[Re: RapidRobert]
#376778
07/16/09 07:05 AM
07/16/09 07:05 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Do your math and you will see that you gained .010 didn't loose it. Using a shim will actually make things worse. You milled .030 and used a .040 gasket. Therefore you increased the distance not decreased. By milling .030 and using a .040 you actually lost ground. Put it together and forget the shims they will make things worse.
[Re: CrAzYMoPaRGuY]
#376783
07/16/09 11:15 AM
07/16/09 11:15 AM
Posts: 7,506 Az
Crizila
Az
If the heads have been redone by others you might wabnt to CC them, just to verify what you got. I am not a proponent of shims, although it is a much cheaper way to go verses push rods and adjustable rockers and a lot of guys do it with no problems. As long as you are within your lifter plunger travel you are ok. If you are running over .5 lift, I'd also be checking the valve stem scrub pattern per what R.R. said.
Fastest 300
