Will 20" caltracs work on an e-body? #376641
07/15/09 09:42 PM
07/15/09 09:42 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I found a set of 20" caltracs that came off a 65 b-body. Does anyone know if they will work on a 70 Challenger? I can call Calvert in the morning but was wondering if anyone here has any knowledge on these?
Chris from New Jersey
Re: Will 20" caltracs work on an e-body? [Re: fig426] #376642
07/15/09 09:51 PM
07/15/09 09:51 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
You could always just buy the 22" bars from Calvert Racing if the 20" A-body length does not work for you. It's been several years, but I remember paying $60 for an extra pair of bars from Travis.
Re: Will 20" caltracs work on an e-body? [Re: Blues_Cuda] #376643
07/15/09 10:26 PM
07/15/09 10:26 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I run that exact setup....20" cal-tracs from a mid 60's B-body with 20" front segment mono-leafs. You need the extended Mopar performance spring hangers that are meant for use with Superstock springs (those also have a 20" front segment).
If you want to use a 22" front segment spring then you need to do as blues_cuda mentioned above.
Re: Will 20" caltracs work on an e-body? [Re: Quicksilver440] #376644
07/15/09 10:43 PM
07/15/09 10:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've seen guys cut and weld 2" into the bar or buy new bar or use mp hanger for SS springs as stated above. I started with the 20 inch then when I went mono went 22
Re: Will 20" caltracs work on an e-body? [Re: fig426] #376645
07/15/09 11:08 PM
07/15/09 11:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I run 20" CalTracs w/ their mono-leaf springs and a set of ARE (AndyF's company) 2" extended front E-body hangers. I stayed w/ the 20" front segment because I switched from SS springs and didn't have any OEM front spring hangers to use w/ the 22" version.
Re: Will 20" caltracs work on an e-body? [Re: BradH] #376646
07/15/09 11:12 PM
07/15/09 11:12 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Thank you all. I just emailed the seller and made the deal. Now the question is....... Which works better? Keeping them 20" or extending them to 22"?
Re: Will 20" caltracs work on an e-body? [Re: fig426] #376647
07/16/09 07:12 AM
07/16/09 07:12 AM
hands down the 20" segment is better.
i didnt like the 22" segment at all.
Re: Will 20" caltracs work on an e-body? #376648
07/16/09 07:16 AM
07/16/09 07:16 AM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
20" CAL TRAC BARS ARE THE TICKET.
YOU WONT BE DISAPPOINTED,THE 22" CAL TRAC BAR IS FOR LATE MODEL B BODY OR F BODY.
Re: Will 20" caltracs work on an e-body? [Re: JACKSON] #376649
07/16/09 09:58 AM
07/16/09 09:58 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I ran the 20" front segment on my challenger and I had dr diffs extended front spring hanger
315/60/15's Et Street Radials
Mopar Performance
Re: Will 20" caltracs work on an e-body? #376650
07/16/09 11:32 AM
07/16/09 11:32 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
That's interesting. When I bought mine I had the 20" front hangers from my SS spring setup and I asked Calvert which spring would be optimum and he said go 22". So I had to buy new hangers.
