turbo small block #376326
07/15/09 03:59 PM
07/15/09 03:59 PM
Canada
bucket Offline OP
bucket  Offline OP
Canada
Has anybody ever put on a single turbo setup on a 340 engine?would like to see pictures and what kind of headers used.(thinking of truck setup headers on a-body)
Re: turbo small block [Re: bucket] #376327
07/15/09 06:57 PM
07/15/09 06:57 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Made my own headers
Now has Borg Warner S480 on it.
Re: turbo small block [Re: RyanJ] #376328
07/16/09 03:55 AM
07/16/09 03:55 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
My car has factory manifolds on a stock headed 318, and with a real launch will run 10's..
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: turbo small block [Re: topfueldart] #376329
07/16/09 07:43 PM
07/16/09 07:43 PM
Canada
bucket Offline OP
bucket  Offline OP
Canada
whats the most boost on a stock 71 340 motor?
Re: turbo small block [Re: bucket] #376330
07/16/09 10:51 PM
07/16/09 10:51 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Should be able to take 36 PSI in stock form .
Not guaranteeing for how long thought. ZING
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: turbo small block [Re: go green] #376331
07/17/09 04:51 PM
07/17/09 04:51 PM
Canada
bucket Offline OP
bucket  Offline OP
Canada
what kind of compression should it have?
Post deleted by Defbob [Re: topfueldart] #376332
07/17/09 06:54 PM
07/17/09 06:54 PM
Re: turbo small block #376333
07/17/09 11:34 PM
07/17/09 11:34 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
12.36 @ 4100ish lbs and only 4-5 lbs of boost factory manifolds untouched. Probably just shy of 500hp. More HP is just a turn of the wastegate away. Find a factory manifold to work with and use your imagination for running the pipes.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
