Re: Doors shut hard after new paint job and weather strips
[Re: B5496RR]
#376121
07/15/09 02:19 PM
07/15/09 02:19 PM
Posts: 15,487 Florida
scratchnfotraction
try rolling down the windows when closing the door mine would trap air in the cab and do the same thing roll the window down some and shut much easier worth the try anyways
[Re: B5496RR]
#376123
07/15/09 03:16 PM
07/15/09 03:16 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Yes there is some breaking in of the new rubber but not a lot. Not enough to cause you to have to re-adjust the doors and they not line up.
There is a brand of seals that are actually too thick and cause this. I can't remember which one but there two types of seals. Someone on here should remember.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: B5496RR]
#376124
07/15/09 03:59 PM
07/15/09 03:59 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Slowly push the door closed and feel to see if it moves up or down as the latch grabs it. If it does then the hinges are out of adjustment and he is using the latch to compensate for it which will wear out the hinges, the latch and on some cars like E-bodies cause the door handles to break. The doors should be fully loaded and the hinges adjusted before the latch pins are installed. That way the latch only latches the door and doesn't force the door into position because of mis-adjusted hinges. My
[Re: Dougsmopars]
#376139
07/16/09 04:41 PM
07/16/09 04:41 PM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
If you used the Soft Seal door seals change them to the Metro Super soft door seals and toss the others in the trash. I had the same problem with my Challenger.
You started a post on this problem in two different sections and are getting two different sets of answers. In this section people are saying the Soft Seals are great. In the other thread they are saying they are junk. Soooo...
Are Year One seals the "Soft Seal" ones? I'm getting confused here.
[Re: RJS]
#376143
07/16/09 05:51 PM
07/16/09 05:51 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
If and I mean If you can't get differant ones try lubing the rubbers up with either silicone or spray lube. Give the doors something to slide on as the door shuts. I have had to do that with differant types of wx strips. Some are good and soft as others have said and some are just to darn stiff. Those are the ones that need the extra help. Try also taking the striker off then shutting the door. You should beable to shut it with ease and hold it shut. If the lines are good then install the striker. If not adjust the door to get good lines. Then reinstall striker. If with the striker off you feel the door binding as you shut it try and note were that is. Maybe there is a spot that the wx strip isn't installed correctly. Compaired to the old one not figuring the age do they look like one another? I also do not agree with the year break in but to agree that they do need to set the memory to the door. As for someone's comment about new cars not fitting. Remember this they sit at the plant for how long with pressure from the doors being shut then shipped to someplace then sit there then are shipped to the dealer. Those rubbers do have time to be worn into fitting. Not as bad as this situation but we don't see new cars directly off the assembly line. I know I never have but I am sure someone can inform me what they are like the moment they come off. MAybe I am wrong?
Contact Me about AMD Prices
[Re: B5496RR]
#376144
07/16/09 05:51 PM
07/16/09 05:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I have a question for those out there who have installed new weather striping on there doors. I had a local custom paint shop perform a complete paint job on my 69 BB. Doors, fenders etc were removed. Upon installation of the doors after paint new weather strips/seals were installed for all windows/doors etc. The doors are lined up nicely with the body panels but the doors need to be slammed to shut. The owner of the custom paint shop has informed me this normal until the seals break in which usually occurs after 1 year, then the doors need to be readjusted and will shut properly. I have never heard or this... Has anyone experienced this before?? I have adjusted the doors so that they shut nicely but they do not line up with the body panels properly. I previous adjusted the doors with the old seals and they could be shut with one finger. Now it requires to slam the door harder them normal...??? And yes the correct weather strips/seals were installed. I doubled checked the part numbers. Any thoughts would be of great help.
I've gone thru this on any restoration project, be it A,B,E body, 68 thru 72,.....The repro mouldings have to taken on an individual basis, meaning just buying entirely Metro, Softseal, or Steele, etc, won't assure you of a perfect fit, there's times I go thru 2 or 3 mfg's mouldings before one fits properly,....of course nice originals/NOS are prefered,....I've never had a fittment issuse with either,......A customers 69 RR I recently did,....I went thru several door seals, from Metro, Soft seal before finally getting the doors to close properly,....as far as 68-70 Chargers, I haven't found any aftermarket seal that allows the door to even close, nevermind latch!,.....if your doing a Charger, use originals, E body trunk strip is another nightmare, everything available is too bulky,
When you compare originals to the repros, most are THICKER, no doubt,....but the needed profile isn't even close, which causes "bulking" in corners, esp on doors, this prevents them from closing,....if used/NOS aren't available, all that's left is careful triming of the repros as the only alternative,.....I can't tell you how many sets of door mouldings I've FUBAR'D trying to get a customers car "squared away"
It seems today if your restoring a car, you buy all the competing mfg's rubber products offered for the car in question,.......sooner or later you might have a "fit" in more way than one!
[Re: Dougsmopars]
#376147
07/16/09 11:14 PM
07/16/09 11:14 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Metro is Soft seal. The company name is Metro soft seal. There 1 in the same
Sorry for the mix up regarding Metro,....their earlier line of "softseals" are like rocks,esp the door seals....the new line of "supersoft gold seals" are much better, in some regards,.....most guys finialy getting around to their restos, may have purchased Metros first generation of seals during the parts gathering endeavor, the new "Sponge" seals, are a slight improvement, probally due to customer feedback about the eariler seals problems,......real early releases of Metros products were on a white cardboard background with the METRO name, the last few years, it's the Purple packaged "Softseal" look,.......now it's the "Super Softseal Gold sponge",.....so I kind of look at the generation of gaskets as Metro (early), and Softseal (later).....sorry if that was confusing
But SOFFSEAL is a seperate manufacturer,......I may have mistyped.....in my original post SOFFSEAL/SOFTSEAL ....my bad
