Trailer question #376059
07/15/09 12:01 PM
07/15/09 12:01 PM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Is it ok to have leaf springs on a 24 ft.enclosed car trailer?
I finally found a trailer I like but wanted to know about the spring setup. Thanks
71 Demon
Re: Trailer question [Re: hemifw] #376060
07/15/09 12:05 PM
07/15/09 12:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its fine if the springs are rated for the capacity
of the rest of the trailer.... BUT usually it will set
higher than a torsional axle
Re: Trailer question [Re: hemifw] #376061
07/15/09 12:21 PM
07/15/09 12:21 PM
That was the standard equiptment for many years, not a problem other than the increased hieght as already said, make sure the gross vehicle rating is adquate for your load and check the tires out very carefully (load rating and condition) before towing with a load
Re: Trailer question [Re: Cab_Burge] #376062
07/18/09 07:47 AM
07/18/09 07:47 AM
North Carolina
CALSDART Offline
CALSDART  Offline
North Carolina
Can the springs be removed to lower the trailer?
Calvin Thompson
Re: Trailer question [Re: CALSDART] #376063
07/18/09 12:00 PM
07/18/09 12:00 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
No, that would change the load rating of the springs. You might be able to find drop axles to lower the trailer, or lowering blocks.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
