Re: New Paint job on a budget thread.
#37594
10/16/07 10:25 PM
10/16/07 10:25 PM
i have found that you can clear the rustoleum with automotive clear coat (KIRKER) for more protection
details please !
did you wetsanded to 2000 then applied the clear? any pictures?
#37595
10/16/07 10:30 PM
10/16/07 10:30 PM
One word of advice: use BLUE tape !
Err, it WAS blue tape. 3M, not cheap stuff. It only did it at these spots. I believe it was due to the water being trapped under it somehow. It pulled off all the rest of the car just fine, even on these same panels for the rest of the length. The one fender had several 'dots' where the paint was, well, not adhered to the primer. Not fish eyes, but dots of lifting paint. I'm pretty sure this is a spot where the plastic sheet was against the fender and probably had moisture trapped under it. Live and learn. I DA'd the spots and primed the bare metal tonight. We'll start building up the coats tomorrow.
[Re: _Scott_]
#37597
10/17/07 10:57 AM
10/17/07 10:57 AM
another bodyshop trick- when you are masking over a fresh painted surface, put the tape across your clean pantleg to break a bit of the adhesive of the tape. It will also help it to keep it from pulling off fresh paint.
#37598
10/17/07 12:56 PM
10/17/07 12:56 PM
I've read this thing over and over and over again, and I think it's a viable alternative for those of us on a budget. My question is this: I understand that metallic paints can't be used because of the roller problems with metallic, but couldn't you paint the car with the methods here but hand cast the micro flakes, let dry, then knock down with a wet sanding then clear coat it? I seem to remember that back before the spray gun, the metal flakes were hand cast like this.
#37599
10/17/07 02:51 PM
10/17/07 02:51 PM
I've tried hand casting metalflakes on some very small parts... It worked OK on these parts, as they were REALLY small (like half inch by 6 inch strips), but even then it was EXTREMELY difficult to get an even distribution of the flakes.
I wouldn't try it on a large area, I think it would end up very blotchy.
#37600
10/17/07 06:43 PM
10/17/07 06:43 PM
I would think that since we're rolling in layers, that if we hand cast over each layer and then wet sand, and then hand cast the next layer and so on , it would and should even out. I have my old satellite hood that I replaced with a Roadrunner bulge hood I think I'm going to try. Just a pinch between the cheek and gums. . .oops, wrong product! I'm thinking maybe something like an old flour sifter or something to help control the dispersal. . .it's worth a try.
#37601
10/17/07 09:07 PM
10/17/07 09:07 PM
Nice Job otherwise. What brand/color blue is that?
#37602
10/18/07 06:48 AM
10/18/07 06:48 AM
Thank you. Aside from my moment of disaster, I'm really pleased with it. Brightside Largo Blue and White. I'm trying to pseudo replicate the old Datsun 510 Trans-Am paint job. It'll get red stripes diagonally on the side of the fenders and front doors yet (done in vinyl; I'm not that crazy). I simply brushed a coat of straight Brightside white on my FUBAR areas last night to get some coverage. It actually went on fairly smooth. I may hit it again before the first sanding. I think it will turn out okay; just horribly deflating thinking you're ready to bolt the car back together and have it on the road only to be set back another week of evenings.
#37603
10/18/07 10:22 AM
10/18/07 10:22 AM
You know - it definitely IS worth a try. I'm all for experimenting - hence using the flakes on my tail-light surrounds. The flour-sifter idea is just sane enough to maybe work! If you can get it far enough from the panel that the lakes drift down fairly evenly...yeah - it might work. Uh-oh...what about the vertical panels?
#37604
10/18/07 11:10 AM
10/18/07 11:10 AM
The vertical panels. . .hmmmmm.... I might try putting the car on ramps one side at a time to elevate the vertical panels a smidge so they aren't perfectly vertical and try to continue with the sifter idea or. ...elevate and use an old talcum powder bottle elevated enough for the dispersal. . I would think that since we are working in layers, it would be time consuming but well worth the try. . .hell, they used to hand cast these things back in the day, so there has to be something on the net about it. . . This is an expensive alternative, but I would think innovators found here could come up with a cheaper alternative http://www.innate.com/Paint/OSF/OSF_Jobber.htmIt can be done. . .low pressure air, I wonder if you could use something like an aquarium pump and supplies?
#37605
10/18/07 02:49 PM
10/18/07 02:49 PM
Hmmmm....if the flakes are small enough, they should be dry-sprayable through any gun with a large enough nozzle, but then we might as well just spray metallics if we've got that kind of equipment. I think the squeezy talc bottle might still give you blotches, as the bulk of the material will be in the initial 'puff' with the surrounding areas getting less.
If you can get the handcasting working on a horizontal panel, why not go for a two-tone? Or even a single tone, but with the flat surfaces 'metallized' - that might be a neat look?
#37606
10/18/07 04:25 PM
10/18/07 04:25 PM
I was a spray painter over 30 years ago, and at that time one of the "old timers" told me they used to hand cast metal flakes when they first came out. (At the time they were big flakes, and wouldn't fit through the gun nozzel.) I also like the dry spray idea. However, don't sand right on the flakes. They are typically colored aluminum, and sanding them will expose the base color, and turn it dark. The guy I knew years ago said they used to go over them with a roller to flatten them out, then put on a heavy clear coat before sanding. Even when using modern spray equipment, clear should be sprayed over a metalflake coat to make sure the flakes are completely covered before wetsanding. Do a test panel and post pictures! LanceB
#37608
10/18/07 10:35 PM
10/18/07 10:35 PM
Project Double Displacement Walkaround Video: http://www.cobra4me.com/phpBB/Paint1.phpIt is still not done, but putting it back together, the rear spoiler and front section have been painted with 2 coats of rusto, will apply another 2 coats of Brightside. Most of the car has been Polished using PoorBoy's SSR3, will do another coat of SSR2.5 and then another of SSR1 The first part of the video I did in low resolution so it shows a bit grainy.
#37609
10/18/07 10:54 PM
10/18/07 10:54 PM
Results: I'm overall very happy with it. Pretty smooth even without the final wetsanding and polishing. This was using the gloss sail blue color.
#37610
10/19/07 06:59 PM
10/19/07 06:59 PM
I had a crazy idea.
I used Rustoleum primer in my engine bay, which was stripped to bare metal. To apply it I mixed Penetrol with the primer and used the Harborfreight rechargable spray can. That spraycan did not work out so well for me, it just shot little globs of paint, but the best part was that the paint self-leveled well enough so I got a pretty smooth coat of primer.
So the idea is...what about using a $2 plastic spray bottle, like those you can buy at Home Depot (similar to what Windex comes in) to apply the paint? I would think the spay would be localized enough that it wouldn't kick up enough dust to by like really spraying, but should apply the paint in small enough particles that if you thin it it should self-level fairly well an merge into a uniform coat. You would have to set it to the widest spray pattern so it was more like mist than a stream of paint.
Is this idea even worth testing?
#37612
10/19/07 09:38 PM
10/19/07 09:38 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
The trick will be to find 'the right' spritzer bottle. Each type of hand pump spritzer is designed for the viscosity of the fluid it is trying to vaporize.
Windex bottles might not work too well, because the fluid being spritz'd is extremely thin. So you need to find a spritzer bottle that was designed to spritz a heavier fluid.
It might take a bit of shopping around to try to land on 'the right' spritzer to pump out and vaporize thinned paint.
One of the chaps here used one of those self-contained pumpers ( where you slap a C02 cartridge or a can of compressed air on to the sprayer bottle ) They found that it tended to clog up in rather short order.
But the hand pumped type spritzer might be able to do it. The most expensive hand type pumper would be one of those big pumpers that you put insecticide into for spraying your lawn. You pump the handle to propel it out the flexible hose.
But there must be something cheaper out there that can generate enough pressure to spritz the thinned paint out of it...
[Re: Marq]
#37613
10/22/07 10:21 AM
10/22/07 10:21 AM
hello.
so i decided to try this method. i did all the body work primed the car wetsanded and preped it for paint.
i mixed it 1:1 with mineral sprits (im using tremclad/rustoleum), when i apply it on the car its really glossy but this mornign when it dried it was flat no shine whatsoever.
should i be taking out as much pant as i can from the roller then apply very thin coats on the car?
thanks
