Re: Tire Pressure for MT ET street Drag Radials?
[Re: joflaig]
#376031
07/15/09 12:01 PM
07/15/09 12:01 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I run the 295-65 radials at 19-20 psi for best traction. I've run the 275-60s and had good luck with them at around 18 psi, but never tried them any higher...didn't use them but a couple times at the track. I normally street drive with around 25 psi in them. CHIP
[Re: an8sec70cuda]
#376032
07/15/09 12:10 PM
07/15/09 12:10 PM
I run mine at 16psi..at the track
[Re: joflaig]
#376033
07/15/09 12:18 PM
07/15/09 12:18 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
Not all tire gauges read the same on the same set of tires The message there is to get a good tire gauge and use it ONLY on your car(don't loan it out either )and find which pressure works best on your car. I have ran several sets of M/T 315x60x15 on my car on the street and strip, 17 to 22 lbs on both uses. I try to remember to pump them up for crusing on the street to maybe 25 lbs, if I remember Don't expext those tires to last like a regular street tire If you can get 10,000 miles out of them on the street you will be doing great
[Re: Triple Threat]
#376035
07/15/09 02:09 PM
07/15/09 02:09 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
www.mickeythompsontires.com will be the best place to look.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
