Torque on flexplate to crank bolts? #375906
07/15/09 09:34 AM
07/15/09 09:34 AM
KY
juicedcuda Offline OP
KY
What is recommended torque on fleplate to crank bolts? 8 bolt flexplate and should I use loctite?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Torque on fleplate to crank bolts? [Re: juicedcuda] #375907
07/15/09 09:36 AM
07/15/09 09:36 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
55 ft/lbs.
I use red Loc-tite.
Re: Torque on fleplate to crank bolts? [Re: S/ST 3040] #375908
07/15/09 10:44 AM
07/15/09 10:44 AM
KY
KY
The thread on these bolts is 7/16-20 correct?
Re: Torque on fleplate to crank bolts? [Re: juicedcuda] #375909
07/15/09 11:01 AM
07/15/09 11:01 AM
S/ST 3040 Offline
S/ST 3040  Offline
Yes. I know you can probably crank them up to 75 ft/lbs. but, IIRC
the Service Manual says 55 so, that's what I've always used. I
never had one break or come loose.
Re: Torque on fleplate to crank bolts? [Re: S/ST 3040] #375910
07/15/09 11:07 AM
07/15/09 11:07 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
You sure they're not 1/2 inch bolts on an 8 bolt flange?
Re: Torque on fleplate to crank bolts? [Re: buildanother] #375911
07/15/09 11:24 AM
07/15/09 11:24 AM
S/ST 3040 Offline
S/ST 3040  Offline
Actually, I'm not sure. All of my bolt packages are for 6-bolt stuff.
I appologize if I've misinformed anybody.
1/2-20, I'd go 75 ft/lbs.
