hey guys,
I have a 67 belvedere that was pretty much gutted of all acc. for moonshining before i bought it, i.e no heater or air components, no windshield washer fluids, batt in trunk etc etc etc.
I have a nascar style steering wheel on the car as well , aftermarket tach. and gauges , I have no horn on the car and wanted to add one to it. i actually got a road runner beep beep horn from a junk swap meet and wanted to test it out.
What sort of advice do you have for trying to connect this thing. If i say buy some horn button kit i could put under the dash. I have limited knowledge of wiring but i do have wiring schematics for the car. Could any of you describe where the wires should be going in the circuit if i cant find the proper ones in the schematic behind the dash. I have no idea what was chopped off back there.
If you could describe where to run the wires and the need for a relay etc if i install some kind of third party horn button, what could i do?
thanks for any direction
I appreciate it as a newbie
chuck .
