Re: Manual brakes master cylinder bore sizes
[Re: Stanton]
#375823
07/16/09 04:18 PM
07/16/09 04:18 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
the optimum size master will depend not only on how many pistons you have, but what their diameters are. I measured the single piston sliding calipers on my Dakota, and did some math taking into account the leverage advantage I have with my pedal, and decided that I needed a 7/8" master cylinder to achieve the 1200 psi for disc brakes using only 50 lbs of leg pressure. I then let the "experts" at master power sell me a 1" bore master, saying that I absolutely needed the larger bore for the disc brakes, and that anything smaller was just plain unsafe.
after I had it all put together and running, I had a really hard pedal! I then found out that the original POWER master cylinder was only a 15/16" bore, so much for needing the 1" for discs! I could have gotten away with the 7/8" that I originally calculated that I needed.
oh well. I'll keep what I have for now because I plan on upgrading my 98 dakota front brakes to an 03/04 Dakota set up, the discs are a inch larger, and the calipers went to a dual piston sliding caliper, and it's all a simple bolt on deal, just swap out the whole spindle at the ball joints!
**Photobucket sucks**
[Re: Stanton]
#375828
07/16/09 11:16 PM
07/16/09 11:16 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Ok, got everything apart except for the rod - it won't come out of the piston !!! Don't want to start hammering anything ... any suggestions ??
I've read of plenty of methods on Moparts, back in the 70's was the last time I did one & I did it the hard way... The best suggestion I've read is to pull the saddle off your floor jack, slide the rod throught the open hole with the piston sittng on top of the plate now pass a heavy rod through the hole in the rod then just jack the thing apart..
[Re: 1_WILD_RT]
#375829
07/17/09 09:06 AM
07/17/09 09:06 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Well, I didn't do it exactly like that but a very similar way. Now I need to fing a new doohickey that holds the rod in the piston 'cause pulling it apart ruined it !!
So what happens when you use a 1&1/8 M/C on a PB setup?
You go through the windshield if you so much as touch the brake pedal !!! All joking aside I would imagine the brakes would be just too touchy - more like an on/off switch.
