Re: bone stock 440 rear wheel horsepower
[Re: 440trk]
#375773
07/15/09 04:15 AM
07/15/09 04:15 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
you will make more ponys by changing to a different set of heads. I had a set of 516s on my 71 RR. at the 1000 ft make it would quit pulling. changed to a set of 452s and it pulled hard all through the 1320...
I am truckless..
[Re: DaytonaTurbo]
#375777
07/15/09 12:10 PM
07/15/09 12:10 PM
so if im makeing 280 with an auto that seems right?
Probably.
With a mild cam, headers and otherwise stock long block ( intake, heads, pistons, etc.) and 9.5:1 mine made right at 320 at the rear wheels.
It was rated at 350 and my mods added about 50 gross HP so gross it was right at 400.
[Re: Nick Mineau]
#375780
07/15/09 12:22 PM
07/15/09 12:22 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
i gust read a artical where mopar performance tested a 440 that was 100% stock. 240 rear wheel horsepower. a second artical test a diffrent one 252 horsepower. and a 69 six pack 4 speed stock made 280.
seems like im doing pretty good for a automatic with exaust manfolds and 516 heads. sense the dyno day i switched to headers and gave it a tune up. what a upgrade id like to dyno again and think it would make close to 300 hp. the car moves very well. its a 76 duster that weighs only 3300 lbs. this summer im buying slicks and going to the track. any guesses on the et?
sometimes you answer your own questions with the help of others, thanks!
http://www.race-cars.net/calculators/et_calculator.html
12.95 @ 105
[Re: Mr.Yuck]
#375782
07/15/09 01:24 PM
07/15/09 01:24 PM
Posts: 1,261 ILL
mark7171
ILL
Niether here nor there, but on dyno day we got put our student cars on the dyno. Same dyno same day. All different cars rwhp, in fairly good running condition. I just quickly wrote down car and hp# on a notebook, because we were hustling. No rpm or torque. here-
schools 350 stock iron 4 hole intake auto tbucket 172 hp
schools 350 tubucket performer intake , stock 206hp
350 tbucket performer intake, perffomer cam,performer heads 268 hp
350 t bucket rpm manifold,rpm heads,rpm cam 288hp
FI 350 stock 94 ex cop caprice made 156hp
a 360 auto 83 diplomat ex cop made 202hp
a 307 2bbl 69 auto chevelle made 162hp
a chevy half ton 350 auto tbi made 151hp
a 89 fox K+N filtercharger/exhaust 5.0 5spd made 210hp
a stock 88 5.0 auto Tbird made 180.
a honda civic "160hp" 5 spd made 130hp
a 4.3 s10 auto stock made 144hp
a 95'integra 5spd made 127hp
a berretta 2.8 v6 stock made 102
a corsica 3.1L LTZ made 138
a kia sephia 5spd made 81hp
a 3.8l bonneville made 155hp
a mekur XR4TI 5spd made 177hp
a ls1 camaro 6spd K+N filter, exhaust,306 hp
a dakota r/t 360 made 185hp
318 600cfm, cam, heads, 4 spd, headers 70's 238 hp
supercharged GM 350 55'2dr,specialty blower cam, headers, 350 hp at 6 psi
[Re: Nick Mineau]
#375783
07/15/09 10:12 PM
07/15/09 10:12 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
One of my buddys was getting 305-310rwhp out of a mostly stock '67 440 in a 67 R/T, as in mostly stock it had been rebuilt with flat tops at 0 deck, had a MP magnum resto cam, a 750 AVS off a '69 but still the OE 67 air cleaner, the 915's had been rebuilt with a good valve job but no porting, standard non HP manifolds with a 2.5" mandrel bent exhaust and full size dynomax hemi mufflers.
On M&H G60 street slicks it runs 12.8's@107, it's all low RPM he shifts at 5400 and it floats the valves at 5800.
