Can Lifters go bad? #375721
07/14/09 10:44 PM
07/14/09 10:44 PM
Motor City
73Convertriple Offline OP
Motor City
Rebuilt 360 4-speed in a 73 dart sport. Motor had a good break-in with brad penn break-in oil left in for first 500 miles per builders suggestion.Switched to shell rotella after first change of oil. After about 800 total miles motor started ticking on cold startup after sitting for a few days. Lasts for say 3-5 minutes, exhaust note sounds odd and runs a little rough. sound goes away and motor smooths out.Runs fine after that, yet always has the same symptoms after sitting for say 5-6 hours.no overheating missing or other symptoms
Could it be a lifter gone bad and bleeding down? I pulled the valve covers and did not notice anything obvious a miss, no bent pushrods or rocker adjustments let go. Has comp cams pro magnum adjustable rockers. Thinking of pulling the intake and inspecting lifter and cam to eliminate fear of wiped cam lobe.
Re: Can Lifters go bad? [Re: 73Convertriple] #375722
07/14/09 10:52 PM
07/14/09 10:52 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Find the noisy lifter and check the adjustment. One rocker may have gotten a bit loose.
Re: Can Lifters go bad? [Re: Dougsmopars] #375723
07/14/09 10:59 PM
07/14/09 10:59 PM
scratchnfotraction Offline
get of the rotella
mine did the same thing,high milage engine
I use a good straight 30 weight oil from napa
with a good wix filter
like said check lash if adjustable or replace lifter/push rod/rocker on offending valve,if non adjustable
good luck and hope it did not wipe a lobe
Re: Can Lifters go bad? [Re: Dougsmopars] #375724
07/14/09 10:59 PM
07/14/09 10:59 PM
Motor City
Motor City
I do have an old set of valve covers.Thinking of cutting the tops off so i can run it without oil running out all over the exhaust mainfolds. I did spin push rods and could not feel any of them being loose ones that were on base of cam lobe at least. I need to hook up my remote starter and tap motor over to check the ones that valves were open. Suppose you could be right just a little loose could do it.
Re: Can Lifters go bad? [Re: 73Convertriple] #375725
07/14/09 11:07 PM
07/14/09 11:07 PM
Dougsmopars Offline
Dougsmopars  Offline
And he's right lose the Rotella oil. I'm old school 20 50 Castrol. In almost 40 years of beating the hell out of Big Block mopars i've never had an oil related problem.
Re: Can Lifters go bad? [Re: Dougsmopars] #375726
07/14/09 11:10 PM
07/14/09 11:10 PM
Motor City
Motor City
sounds like an oil change is on the list of things to do also. I do use a wix filter.
Re: Can Lifters go bad? [Re: Dougsmopars] #375727
07/14/09 11:15 PM
07/14/09 11:15 PM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i agree with changing the oil to castrol 20/50 and also run some lucas oil treatment, i have the same noise with a 440 with xe 274 comp cam
this oil combo helps
Re: Can Lifters go bad? [Re: cornet684me] #375728
07/14/09 11:23 PM
07/14/09 11:23 PM
Dougsmopars Offline
Dougsmopars  Offline
With any flat tappet cam you need to use a Zinc additive. Since rollor cams became factory spec oil companies have reduced the zinc levels in oil. Did so as to lower emissions. But flat tappet cams need the zinc. Ever oil change i add a bottle of ZDDPlus from Kirban Performence. High Zinc forular. There web site is kirbanperformence.com
Re: Can Lifters go bad? [Re: cornet684me] #375729
07/14/09 11:25 PM
07/14/09 11:25 PM
Motor City
Motor City
Oil change is definitely easier than pulling intake to inspect lifters and cam.Dont think it is a wiped lobe as it goes away after a few minutes.Did start a few hundred miles after draining brad penn breakin oil. Thanks for the tips i'll try it tomorrow if I can get the kids to bed early enough, Heck I'll have my 6 year old do the oil change for me, he loves wrenchin on the dart and feelin chirpin of the gears from the back seat. How about the high zinc oil additive I've read about here?
Re: Can Lifters go bad? [Re: 73Convertriple] #375730
07/14/09 11:32 PM
07/14/09 11:32 PM
Dougsmopars Offline
Dougsmopars  Offline
The high zinc additives are good for us flat tappet guys. No need in roller motors
Re: Can Lifters go bad? [Re: Dougsmopars] #375731
07/14/09 11:35 PM
07/14/09 11:35 PM
try some thicker oil. EDIT Your cam/lifters are fine
Re: Can Lifters go bad? [Re: RapidRobert] #375732
07/15/09 10:55 AM
07/15/09 10:55 AM
Motor City
Motor City
Thanks for all the info, I will Run it to warm it up then do an oil change with a zinc additive. What zinc additive can i get locally? Did someone here mention one available from the GM Dealer?
I'm in metro detroit area
Re: Can Lifters go bad? [Re: 73Convertriple] #375733
07/15/09 01:15 PM
07/15/09 01:15 PM
Motor City
Motor City
Talked with my engine builder and he suggested using brad penn 10w-30. I used the brad penn breakin oil yet had switched to rotella after first 500 miles. He also suggested increasing the preload of the lifters, 1/4 turn of adjusters. I have the comp cams pro magnum rockers which are adjustable. Going to adjust the rocker 1/4 turn, button it up, warm it up and do the oil change
Re: Can Lifters go bad? [Re: 73Convertriple] #375734
07/15/09 04:20 PM
07/15/09 04:20 PM
Dougsmopars Offline
Dougsmopars  Offline
I'd leave the rocker adjustment alone for now and do the oil change. I'm not big on 10 30 in a performence motor. Maybe i'm old school but i'll stick with 35 years of good luck with 20 50.
Re: Can Lifters go bad? [Re: Dougsmopars] #375735
07/15/09 04:30 PM
07/15/09 04:30 PM
oil and filter change first
I use some of the STP oil tratment for extra ZDDP,said it right on the bottle,the 4 cyl "red" bottle is supposed to have more ZDDP in it too..
the GM ESO is good addative also
running a good diesel fleet oil is good,I use the napa fleet brand in the 15/40 grade also
I read the roller lifters need a little lighter/thiner oil to make sure the needles in the roller get lube good...they only get "splash oiled"..
some edm oiling on flat tappets and pressure lubed roller bearings on the lifter is the new cats meow..so I have read anyways
had no probs with the straight 30 or the 15/40 deisel oils so far on mine
and I to have run the 20/50 for yrs
Re: Can Lifters go bad? [Re: Dougsmopars] #375736
07/15/09 05:27 PM
07/15/09 05:27 PM
IL
furious70 Offline
furious70  Offline
IL
If the builder specs a 10w30 oil, the clearances should be such that 10w30 is the best choice. If the builder doesn't know how to do that right then you're going to be having other issues soon I'd say.....
Rotella is supposed to still have one of the best additive packages, funny everyone here is saying to get rid of it when almost every other forum (diesel, cbody, motorcycle) I read hails it as a good choice as other modern oils are becoming harmful to our classic engines.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Can Lifters go bad? [Re: furious70] #375737
07/16/09 11:21 AM
07/16/09 11:21 AM
Motor City
Motor City
Builder suggests 10w-30 for my 360. My motor was built as a "steet strip package". He said my motor should run @ 25 pressure hot at idle and 50 psi when off idle. I'm going to warm it up do the oil change with the brad penn 10w-30 and a WIX filter as he recommends (I use WIX anyways). Then I will Check the pressure to verify where it is at. I had looked at the gauge I have under the hood and verified it had pressure not specifically what it is at, my bad I guess. Only had under hood small screw in gauges for break in monitoring as I'm going for the stock interior look. Thanks for all the input, hope to get to it tonite.
