Ignition key switch removal #375635
07/14/09 09:57 PM
07/14/09 09:57 PM
Nova Scotia
gearbanger Offline OP
Nova Scotia
I've got a '73 Duster that won't start because the guts of the ignition key lock are shot. How do I get the crome switch cover off so I can replace the lock?
Re: Ignition key switch removal [Re: gearbanger] #375636
07/14/09 10:12 PM
07/14/09 10:12 PM
You have to pull the steering wheel(& more) until you can release it inside the column & pull it out the side.
Re: Ignition key switch removal [Re: RapidRobert] #375637
07/14/09 10:38 PM
07/14/09 10:38 PM
Nova Scotia
Nova Scotia
Thanks RapidRobert. You should get paid for the vast knowledge you keep imparting on us.
Re: Ignition key switch removal [Re: gearbanger] #375638
07/14/09 10:40 PM
07/14/09 10:40 PM
You are too kind
Re: Ignition key switch removal [Re: gearbanger] #375639
07/15/09 01:18 AM
07/15/09 01:18 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 73 Factory Parts Book
Re: Ignition key switch removal [Re: Snoopy] #375640
07/15/09 01:27 AM
07/15/09 01:27 AM
Snoopy Offline
Snoopy  Offline
2
