alternator wiring #375503
07/14/09 09:08 PM
07/14/09 09:08 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
i need a little help i have a 69 dodge dart with a 360 and there is no wires on the alternator i need to know where to connect wires and what they hook to so i can get my alternator charging my battery again. i know the thick cable runs back to the battery but what about the 2 fld wires where do they go thanks for any help
Re: alternator wiring [Re: cole63b] #375504
07/14/09 09:41 PM
07/14/09 09:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Here's a simple diagram
Re: alternator wiring [Re: cole63b] #375505
07/15/09 09:43 AM
07/15/09 09:43 AM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
ok does it matter what fld wire goes where thats my issue is there is no wires at all on the alternator and there is no voltage regulator or ballist resistor there either i have those parts just dont wanna mess this up and burn something up
Re: alternator wiring [Re: cole63b] #375506
07/15/09 09:53 AM
07/15/09 09:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Either field wire can go to the regulator... the other
goes to a switched 12 volt as a sensor
Re: alternator wiring [Re: cole63b] #375507
07/15/09 06:47 PM
07/15/09 06:47 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
ok thank you for the help
Re: alternator wiring [Re: cole63b] #375508
07/15/09 06:58 PM
07/15/09 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You did see that both field wires go to the regulator
but 1 is spliced to a switched 12 volt ... right
Re: alternator wiring [Re: MR_P_BODY] #375509
07/15/09 09:52 PM
07/15/09 09:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Is this clearer??? The other is hazy on my screen.
http://www.moparts.org/Tech/Archive/elec/21.html
Re: alternator wiring [Re: cole63b] #375510
07/16/09 07:58 PM
07/16/09 07:58 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
ok yeah i have it all figured out thanks for the diagrams now i can get this thing hooked up and going again.
