\\\ Help charging system problem////
#375452
07/14/09 08:45 PM
07/14/09 08:45 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
I am trying to get my my car ready to take to the track this Friday. But now i have a alternator/charging problem. Here is what i am using. 2 red top optima battery's remain 75 amp factory stile alt new stock stile voltage reg rewired alt I used 1/0 gauge wire for both the battery grounds and the bat + wire running all the way to the start relay. I have the blue wire on a switched 12 volts source going to the voltage reg then to the alt and the green wire going from the alt to the other side of the voltage reg. I am using a 6 gauge wire for the main power wire coming off the alt to the starter relay. I have a 4 gauge ground wire on the front of the engine going to the K frame and a 10 gauge wire on the back of the engine going to the fire wall. So i think i have everything wired up right.OK now to my problem. When i start my car with the engine cold and running only the electric fuel pump and water pump. My car alt will put out 14.5 volts at idle and this is checking the voltage at the battery's.But when i turn on my 98 ford thours ( spelling)colling fan with the engine at 150 degrees my voltage will drop down to 12.3 and stay there. What i am trying to say is when my engine gets to operating temp my alt will not charge any more. Even if i turn the fan off. I hope that makes since. SO what could be wrong with my car?? IS 75 amp not just big enough to run my electrical loads now? OR do i need to add a ground at the alt?? I want to put a 100 amp one wire alt on my car but do not have the cash right now. oh for got to say i am running the stock size alt pulley and a march under drive crank pulley. But i do have a stock size crank pulley i can try if you think that will help. Thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: \\\ Help charging system problem////
[Re: mopar65]
#375453
07/14/09 08:57 PM
07/14/09 08:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With the engine up to temp and the fan off does the voltage come up if you bring up the rpm's... did you try to full field the alt
[Re: MR_P_BODY]
#375454
07/14/09 10:13 PM
07/14/09 10:13 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
If your still running the factory ameter I would bypass it and see how that effects things.
68 Barracuda Formula S 340
[Re: TheTieWrapKid]
#375462
07/14/09 11:52 PM
07/14/09 11:52 PM
Posts: 108 st.charles,mo.
dodgem1
st.charles,mo.
i looked up 4 ruuner alt on ebay,a guy out in cali,bult me one in 85 amp.the one wires are good for boats or at the strip ,but if you drive on street,they dont like to charge at low idle,the 440 source conversion uses small alt,built in reg,i even run an idiot light on my volt meter with this system,hhr fan,electric water pump and csr water pump,-jeff
[Re: dodgem1]
#375464
07/15/09 12:28 AM
07/15/09 12:28 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I don't find this to be true....I think it's a myth that may be based on some one wires in the past. My one wire makes 80 amps at idle...my car is mostly street ran...stop and go traffic, drive-thru's, etc. And it kicks on as soon as I start the car....and it idled at 650 rpm until I switched to the solid cam, never a problem at all. And I run the Taurus fan, and electric water pump,electric fuel pump, stereo, headlights, etc.
[Re: mopar65]
#375466
07/15/09 11:41 AM
07/15/09 11:41 AM
MR_P_BODY
thanks for all the help guys and no i am not useing the factory amp guage anymore. Rob do you have a part number for the alt you are using? WAs that alt a bolt on deal or did you have to mod the alt brackets to get it to fit. also rob could you post a pick of it mounted on your car?
what i still don't understand is my car will put out 14.5 volts at idle with everything on except the fan. but as soon as the engine gets warm it will quit charging with the fan on or not and by that i mean my volts go from 14.5 down to around 12.5 with fan off to 11.9 with the fan on.now when my engine is cold like right after i just start it. I will have 14.5 volts at idle.then turn the fan on the volts will drop down to around 12.8. I to think i just do not have a big enough alt. just trying to figure out why it acts the way it does between a cold engine and a warm engine. thanks Mopar65
You should see the voltage start going back up as soon as you turn the fan off... since you say it stays at 12 volts even if you rev it up I think its a voltage regulator or a alt is acting up under heat(something is going open)... thats why I asked if you did a full field check on the alt, that will tell you alot
[Re: mopar65]
#375469
07/17/09 01:27 AM
07/17/09 01:27 AM
Quicksilver440
Central Valley, CA.
I run this one: http://www.summitracing.com/parts/PWM-8-37529/
It is chrome....but the black or natural finishes are cheaper.
Like this: http://www.summitracing.com/parts/PWM-8-47529/
It will use the stock bracket if you grind it thinner to clear the alt housing (thats what I did with my cheap $20 stock style chrome bracket) It only took a few minutes to do....
I don't have a good pic...but here's one:
[Re: mopar65]
#375470
07/17/09 12:34 PM
07/17/09 12:34 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
When the regulator sees the current(voltage?) drop from starting it allows the alternator to charge the battery up until it reaches the voltage your seeing(14.2 or? Once that level is reached it allows the battery to drain down until it SHOULD kick back in and raise the voltage up to 14.2. I would look real close at the regulator, it will heat up components inside and that may be the problem
