No reverse in 727 Trans #375170
07/14/09 04:47 PM
07/14/09 04:47 PM
West Tn
Skunk22 Offline OP
Skunk22  Offline OP
West Tn
I have lost my reverse in my 727 trans. It still has good pull in drive and low and will shift through the forward gears with no problem. It also has netural. When shifted into reverse nothing happens it does not drop the engine RPM or have any rear motion to the car. It was rebuilt about 300 miles ago but it has been over two years so I cannot carry it back to the builder. It is behind a mild 440 and does not see the strip. What could have blown out?
I also need a convertor recomendation. It will be for the 440 with a Comp extreme energy 268X cam and only see mild street action. What stall recomendations should I be running. The one in there now is locking up at idle.
David
Skunk's Den 1964 Impala Conv. 1966 Vette 427 1969 Super Bee 2005 Mustang
Re: No reverse in 727 Trans [Re: Skunk22] #375171
07/14/09 06:39 PM
07/14/09 06:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
if everything is working ok...drop the pan and check the rear servo and band...
Tony
70 AARCuda Vitamin C
Re: No reverse in 727 Trans [Re: 70AARcuda] #375172
07/14/09 08:18 PM
07/14/09 08:18 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
I'd say rear servo too...
Re: No reverse in 727 Trans [Re: 2DoorPost] #375173
07/14/09 08:37 PM
07/14/09 08:37 PM
Wyoming Michigan
The Beekeeper Offline
Wyoming Michigan
If you have all foreward gears then that's where to look, I have seen the low/reverse servo seal blow out, the retainer fail and the case snap ring pop out more than once, also look for the servo piston cocked in the bore..........Good luck.............Tom.
Re: No reverse in 727 Trans [Re: Skunk22] #375174
07/14/09 09:30 PM
07/14/09 09:30 PM
MNobody Offline
MNobody  Offline
Did you check the linkage adjustment? Just a thought.
Re: No reverse in 727 Trans [Re: MNobody] #375175
07/15/09 02:22 PM
07/15/09 02:22 PM
West Tn
Skunk22 Offline OP
Skunk22  Offline OP
West Tn
Thanks for the replies: The linkage is good I even tried to manually put it in reverse without the linkage hooked up with no luck. I will pull the pan this weekend and check the rear servo and advise my findings.
Thanks again
David
Re: No reverse in 727 Trans [Re: Skunk22] #375176
07/15/09 03:26 PM
07/15/09 03:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would venture saying that either the reverse band broke or the strut came out of place.
Re: No reverse in 727 Trans [Re: MoparforLife] #375177
07/20/09 08:34 AM
07/20/09 08:34 AM
West Tn
Skunk22 Offline OP
Skunk22  Offline OP
West Tn
Any recomendations on stall rpm?
David
Re: No reverse in 727 Trans [Re: MoparforLife] #375178
07/20/09 01:21 PM
07/20/09 01:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Seen a few break!!!
Re: No reverse in 727 Trans [Re: Dodgem] #375179
07/20/09 10:47 PM
07/20/09 10:47 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
That happened to my 727 today. I put it in reverse and nothing happened.
Taking it to my tranny guy on Wednesday.
Hoping for a quick (read: cheap) fix.
