Re: Help needed - Upper rad hose for BB Duster
[Re: stumpy]
#374953
07/14/09 02:41 PM
07/14/09 02:41 PM
Posts: 183 Canada
Mofopar
Canada
Any good parts store should be able to match a new hose to the old one. Just take it to the parts store and have them eyeball compare to what they have in stock.
Not around here unfortunately. Once the "sales associate" types in the model year of vehicle and doesn't see your motor on the computer screen, they look at you like you have 2 heads and flippers.
[Re: 70Duster440]
#374954
07/14/09 02:44 PM
07/14/09 02:44 PM
Posts: 183 Canada
Mofopar
Canada
Take a look a upper hoses for c-bodies.
Thanks. Came up with a gates #20875 that looks close.
[Re: Mofopar]
#374955
07/14/09 03:14 PM
07/14/09 03:14 PM
Posts: 1,075 United States
STLDuster
United States
I used a set of hoses from a '70 Barracuda (383). Had to trim them a little bit but they fit pretty well.
"No great genius has ever existed without some touch of madness." - Aristotle
[Re: Mofopar]
#374956
07/14/09 05:52 PM
07/14/09 05:52 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
Cant find an upper hose anywhere. The existing hose looks to have been cut to fit. 440 motor in a 72 Duster, aluminum rad with neck on passenger side.
Existing hose is a gates, numbers are 76EX50, C07 11 6, D246. These numbers wouldn't pull up any matches at the local parts shop (Canada)
Any help would be appreciated, thanks.
Just today I bought an upper hose from NAPA for my BB engine in an A body with the rad neck on the passenger side, just like yours. Part # is 7196. I'll forward a picture in another post.
[Re: Mofopar]
#374959
07/14/09 11:21 PM
07/14/09 11:21 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
Ask A local Napa for a Gates non rigid flex style hose. You just need to tell them the hose diameter required. I used one in my 74 a body b block with the top hose on the passenger side
[Re: Mopar Grandpa]
#374960
07/15/09 07:31 AM
07/15/09 07:31 AM
Posts: 183 Canada
Mofopar
Canada
Another angle. If you don't have NAPA stores in Canada they should be able to cross reference the part number.
Looks good. We have NAPA stores so I'll try today. Whats the brand you have in the pic? Gates?
[Re: GwaiiEagle]
#374961
07/15/09 07:35 AM
07/15/09 07:35 AM
Posts: 183 Canada
Mofopar
Canada
That would do nicely too. The only flex the guy could show me was straight run and could make the sharp bend out of the water pump. I'll see if they can find this type. Thanks!
[Re: Mofopar]
#374962
07/15/09 08:10 AM
07/15/09 08:10 AM
Mopar Grandpa
Sebring, Florida
The only name I see on the hose is BOMH. But the part number should get you the correct hose. Actually this hose is for a 1964 BB Mopar without A/C but fits perfect.
