Challenger front spoiler location #374877
07/14/09 12:09 PM
07/14/09 12:09 PM
New Brunswick
U
Unfair Advantage Offline OP
U
New Brunswick
Knowing these were dealer installed .. what would be considered the most COMMONLY accepted placement location ?? I looked at a few cars at Carlisle and there is quite a variation.
Re: Ebody front spoilers [Re: Unfair Advantage] #374878
07/14/09 12:11 PM
07/14/09 12:11 PM
cataclysm80 Offline
cataclysm80  Offline
Challenger or 'Cuda? They're very different.
Here's 'Cuda
Tav
Re: Challenger front spoiler location [Re: Unfair Advantage] #374879
07/14/09 12:39 PM
07/14/09 12:39 PM
cataclysm80 Offline
cataclysm80  Offline
OK, I see you changed the thread title.
Here's Challenger
It's a real TA, but it has GM holley carbs, and other stuff has been fiddled with too, so I'm not sure if these spoilers are factory installed.
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374880
07/14/09 12:43 PM
07/14/09 12:43 PM
cataclysm80 Offline
cataclysm80  Offline
Here's a link to a very old thread where I asked the same question... (I still haven't put mine on, soon I hope)
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
If anyone has more measurements or different opinions, please post them. More info is good.
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374881
07/14/09 02:17 PM
07/14/09 02:17 PM
cataclysm80 Offline
cataclysm80  Offline
The first place auto products front spoilers do come with instructions, but not a diagram. First Place has seen some of the instruction sheets that were shipped with the spoilers in the trunk, but so far they have been incomplete or hard to read. These original instructions did provide specific measurements from body crease lines, etc, but the dimensions were not legible. Few dealerships actually measured when installing them anyway. The original instructions specify that the mounting holes should be 5/16 diameter, and that the bolt and washer are inserted from outside the car through the spoiler and body panel, then the nut goes on the backside.
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374882
07/15/09 10:51 AM
07/15/09 10:51 AM
cataclysm80 Offline
cataclysm80  Offline
This is how the front spoilers look when installed according to Floyds measurements. I clamped them in place to see how it looked. This is about how they would look on the car.
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374883
07/15/09 10:54 AM
07/15/09 10:54 AM
cataclysm80 Offline
cataclysm80  Offline
Another pic from below with the spoilers in the same position.
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374884
07/15/09 10:59 AM
07/15/09 10:59 AM
cataclysm80 Offline
cataclysm80  Offline
Some of the guys who've put their own front spoilers on suggested lining them up with the bottom of the valance. This is about how they would look on the car in that position.
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374885
07/15/09 11:02 AM
07/15/09 11:02 AM
cataclysm80 Offline
cataclysm80  Offline
Another pic from below.
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374886
07/15/09 11:04 AM
07/15/09 11:04 AM
cataclysm80 Offline
cataclysm80  Offline
Has anyone out there seen some factory (dealer) installed front spoilers?
Which way do you guys think is more correct?
Tav
Re: Challenger front spoiler location [Re: cataclysm80] #374887
07/15/09 11:10 AM
07/15/09 11:10 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I don't know what is correct but I think the first way you showed it looks best.
Re: Ebody front spoilers [Re: cataclysm80] #374888
07/15/09 11:33 AM
07/15/09 11:33 AM
New Brunswick
U
U
New Brunswick
TAV . I seen what looked to be two orginals T/A`s at Carlisle ..one the way as you posted and the second as Floyd posted . I would really like a consensus on the most common placement. What about commentary from Alaskan TA ?? or TROY
Re: Ebody front spoilers [Re: Unfair Advantage] #374889
07/15/09 08:05 PM
07/15/09 08:05 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They were installed at the dealerships, so there is a lot of varience.
I have being trying to find a set of the dealership instructions that came with them for about 14 years now with no luck at all.
If anyone has a copy, I would love a scan of it.
Re: Ebody front spoilers [Re: Alaskan_TA] #374890
07/16/09 12:51 PM
07/16/09 12:51 PM
cataclysm80 Offline
cataclysm80  Offline
Does anyone know what the correct hardware to use is?
First Place Auto supplies the repros with nuts with encapsulated washers (which look potentially correct), and also some hardware store looking bolts & washers.
Is that what mopar used, or should I hunt down some regular body bolts?
Tav
Re: Ebody front spoilers [Re: cataclysm80] #374891
08/12/09 10:50 AM
08/12/09 10:50 AM
cataclysm80 Offline
cataclysm80  Offline
Here is a better diagram with floyds measurements on it. Measurements are to the center of the hole. Locate & drill the inside hole first. Put an original or First Place Auto Products spoiler on with a bolt through the hole. Using the measurement from the diagram and the spoiler as a template, locate & drill the outside hole. Put a bolt through that hole also. Now that the spoiler is located, use it as a template to mark and drill the other mounting holes.
Tav
(click on the word "Attachment" above for a larger image)
Re: Ebody front spoilers [Re: cataclysm80] #374892
03/09/13 04:41 PM
03/09/13 04:41 PM
BDW Online content
BDW  Online Content
Getting ready to install my front spoiler tips.
Any new updates or ideas where to locate these?
Seems like the 2nd pic, locate to bottom of valance, is the way I'm leaning.
Yes I know this is an old thread, it has the best info I could find.
Thx
