Trans problem? #374829
07/14/09 11:36 AM
07/14/09 11:36 AM
Champlin Mn.
2
2DoorPost Offline OP
Champlin Mn.
1969 Super Bee automatic trans,at wide open throttle in first gear it feels like something dragging,like the brake is on.When it shifts second gear it launches like it should and everything is fine.Could this be a band adjustment,or a band is not releasing properly? Any easy way to check this out? The trans has about 5000 miles on it.Please help!!
Re: Trans problem? [Re: 2DoorPost] #374830
07/14/09 03:09 PM
07/14/09 03:09 PM
Champlin Mn.
2
Champlin Mn.
No replies? Should this be in the Race section?
Re: Trans problem? [Re: 2DoorPost] #374831
07/14/09 03:14 PM
07/14/09 03:14 PM
scratchnfotraction Offline
is this stock throttle pressure control linkage or a manual valve body?
if its stock linkage it could be adjusted to far back maybe??
and is this you shifting it manualy or auto shift by it self?
Re: Trans problem? [Re: scratchnfotraction] #374832
07/14/09 03:20 PM
07/14/09 03:20 PM
Champlin Mn.
2
Champlin Mn.
Stock control linkage,it's when I shift manually I guess I don't know if it does it if I let it shift on it's own.The linkage is adjusted the same as when it was put together 8 years ago.
Re: Trans problem? [Re: 2DoorPost] #374833
07/14/09 03:24 PM
07/14/09 03:24 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
It is just now doing-this ...after 5k miles? Is it dragging in 3rd also ?
Re: Trans problem? [Re: BeEtLeJuIcE !] #374834
07/14/09 03:29 PM
07/14/09 03:29 PM
Champlin Mn.
2
Champlin Mn.
It started doing this at the end of last season,it only seems to do it in first gear.I'm not a trans guy I was thinking a band isn't releasing quickly enough or something along those lines?
Re: Trans problem? [Re: 2DoorPost] #374835
07/14/09 03:36 PM
07/14/09 03:36 PM
Florida STAYcation
Florida STAYcation
Band isn't releasing ? .. my thoughts also. But it should be doing this in 3rd gear also.
Some years ago ...I remember doing a trans that the lining of the band separated and jammed-up on the drum.
Re: Trans problem? [Re: BeEtLeJuIcE !] #374836
07/14/09 04:31 PM
07/14/09 04:31 PM
colorado
scat340 Offline
scat340  Offline
colorado
Would agree, sounds like the rear band is not releasing. Could the rear piston be stuck in the bore?
Re: Trans problem? [Re: scat340] #374837
07/14/09 04:37 PM
07/14/09 04:37 PM
Champlin Mn.
2
Champlin Mn.
I'll drive it tonite or tomorrow and check to see if it does it in third gear.I don't think it does.I drove it about two weeks ago,it didn't act this way then, kinda weird it does it when it wants to.
Re: Trans problem? [Re: 2DoorPost] #374838
07/14/09 07:50 PM
07/14/09 07:50 PM
Champlin Mn.
2
Champlin Mn.
bump
Re: Trans problem? [Re: 2DoorPost] #374839
07/14/09 08:09 PM
07/14/09 08:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
In 1st gear the rear band being applied or dragging would not cause this problem , if he were to put the trans in manual low the rear band is APPLIED.
second gear rear clutch still applied , front band grabs the front drum , if the rear band was not releasing he would not have a clean shift and the car taking off as it normally would .
First is the rear clutch applied , the front band is released and the front clutch is released , the only things I would think that would cause this is if something was jamming up the front drum ???
Re: Trans problem? [Re: JohnRR] #374840
07/15/09 09:36 PM
07/15/09 09:36 PM
Champlin Mn.
2
Champlin Mn.
Anybody else? I'd like to drive it to Car Craft this weekend but I don't know if I can trust it !
Re: Trans problem? [Re: 2DoorPost] #374841
07/15/09 09:43 PM
07/15/09 09:43 PM
Florida STAYcation
Florida STAYcation
PULL the pan and see if the band-apply lever is operating.
Re: Trans problem? [Re: BeEtLeJuIcE !] #374842
07/15/09 10:58 PM
07/15/09 10:58 PM
Champlin Mn.
2
Champlin Mn.
I'll try that thursday. Thanks!
