Re: 9 Second car fuel systems
[Re: 66coronet]
#374812
07/14/09 11:45 AM
07/14/09 11:45 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Holley "Large port" regulator, -8 feed, -6 return, and holley volumax 250 pump. Previously i ran a holley black deadheaded, and saw zero gain making the above swap. Count me as one of the few who consider exotic fuel systems as generally WAY overkill. Take a look at a needle and seat sometimes to see what the engine is at the end of the line slurping fuel from
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#374813
07/14/09 11:58 AM
07/14/09 11:58 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
My system is a C & S Specialties belt driven fuel pump. I also mounted a 3 gallon fuel cell under the hood, so my entire fuel system is right there.
No problems, no high fuel pressure beating on the needle and seat. 3 lbs at idle, 12 lbs at full throttle. Also no amperage draw and you never have to remember to turn it on or off.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#374814
07/14/09 12:09 PM
07/14/09 12:09 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Enderly 80A pump, 3 gal. tank up front, #12 feeding the pump, #8 feeding the barrel valve, plenty of fuel.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: 66coronet]
#374815
07/14/09 12:10 PM
07/14/09 12:10 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
I haven't ran a 9 second run yet, 10:34 ET at 128.6 MPH(3400 Lbs cork up on pump gas, motor only) best with old 275 Magnafuel pump and system. The system is a #10 feed to the BG 500 filter then into the Magnafuel 275 pump, #8 bypass to the tank from the pump and a #8 to the BG four port regulator feeding three # 6 lines to the six pak carbs. That set up was not enough for the motor(518C.I. pump gas low deck stroker with CNC Eddy RPM heads) based on having a AFR reading of 14.2 at WOT throttle at the starting line and leaning out to 15.3AFr at the finish line no matter what size jets I put in the carbs I changed the pump to a Magnafuel 300 and the AFR went to 11.8 to 12.2 the entire run and slowed the car down on ET and MPH. My message is get the big one to start with, over kill on the fuel system is a good thing as you know you want to go faster and probally will need more fuel in the future for a more powerful combination I wished now that I would have bought the Magnafuel 500 pump to start with
[Re: Cab_Burge]
#374816
07/14/09 12:36 PM
07/14/09 12:36 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Holley Black, K&N high flow filter, -8 line, BG heat sink, Holley regulator split into to -6 lines feeding the bowls. Dead head system.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: RonP]
#374819
07/14/09 01:04 PM
07/14/09 01:04 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Stock tank with a sump welded in, Aeromotive street rod pump (their little street pump), Russell inline filter b/t pump and tank, Aeromotive 2 port regulator mounted right at the carb. -8 line up to the regulator, -6 lines to the bowls. It's a simple dead headed system that's worked flawless for many years. CHIP
[Re: Lil Demon]
#374823
07/14/09 01:55 PM
07/14/09 01:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A pair of Holley black 150 pumps, 2 tree collector style filters before the pumps, good filter after and a Mallory 4 port regulator with return
[Re: 66coronet]
#374827
07/14/09 04:28 PM
07/14/09 04:28 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Brent are you the one that was interviewed on PinksAllOut? Neat car!!!
I ran 9's in my last car with a Holley Blue pump and -8 line, Paxton regulator with -6 lines to the carb, dead headed.
On my current car the Holley black pump broke, so I ran the line to the Mallory Comp250 pump that was on the other side of the car for the old nitrous days. The pump is overkill but I like the fact that it has a return line that goes right from the pump to the fuel cell, and it's actually fairly quiet. I just have a cheap Holley blue regulator also.
