Re: Recommend a SB stroker kit
[Re: 72swgnr]
#374298
07/13/09 10:27 PM
07/13/09 10:27 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I pieced one together I got a Callies crank a set of Scat H Beams that checked good OOTB and a set of custom diamond slugs.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: rt66jim]
#374300
07/13/09 11:09 PM
07/13/09 11:09 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I prefer piecing them together as there really is none that have just what I want ootb.
I got a good deal on a couple mopar cranks one cast and one forged both of them check out real good as well as the cast mopar crank I used in my other stroker motor.
I have used several sets of I beam SCATS seen a few eagles and will never use a set just eyeballing them and knowing about their junk alloy. I was suprised to see Ryans answer to my other thread but he is someone whom I respect their opinion a lot.
I really like I beams for there light weight and easy fit into strokers. They are a lot stronger than people give them credit for, NASCAR guys pretty much all run I beams for one example.
Also off the shelf piston choices really suck, you either get a 21cc or so dish or a flat top. You either get too much compression or not enough.
Custom pistons about 15 cc or so usually work good. Flat tops are fine if you run huge open chamber crappy head or race gas.
I think your best bet is to call DRAM tell him what you want and let him put together a kit for you. Get the parts you want the service you deserve have them shipped to your house, massage them how you want then have them balanced locally.
[Re: formula S]
#374302
07/14/09 02:23 AM
07/14/09 02:23 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
i bought my stuff off e bay eagle parts/ ross pistons. everything checked out fine
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#374303
07/14/09 06:54 AM
07/14/09 06:54 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I bought a kit from Dram. Lightweight K-1 H-beams, K-1 forged 4.00 crank, and custom Diamond pistons.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#374304
07/14/09 09:26 AM
07/14/09 09:26 AM
Posts: 1,178 Indy
FlyFish
Indy
I pieced mine together; Eagle forged crank, Scat I-beams, custom Diamond pistons, total seal rings. Everything had good fit and finish.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
