'98 dakota 2wd hub/spindle nut torque spec. ?
#374090
07/13/09 04:03 PM
07/13/09 04:03 PM
Posts: 1,448 right between milan dragway & ...
Flite_727
my hub/wheel bearings are toast, anyone know the torque specs. for the spindle nut? i'm on my way out the door now to price the hubs. thanks-jeff
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: '98 dakota 2wd hub/spindle nut torque spec. ?
[Re: Flite_727]
#374091
07/13/09 05:41 PM
07/13/09 05:41 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I don't know off the top of my head, but I have a 98 Dakota FSM at home, I'll look it up when I get home tonight to let you know what the factory calls for...I think it's around 70-80 ft lbs? I don't know...might be more though.
**Photobucket sucks**
[Re: 70Cuda383]
#374092
07/14/09 06:09 AM
07/14/09 06:09 AM
70Cuda383
Marysville, O-H-I-O
Page 2-10 of the FSM calls out for 185 ft lbs for the nut that holds the hub onto the spindle. whew, that's a lot!
[Re: 70Cuda383]
#374093
07/14/09 06:13 AM
07/14/09 06:13 AM
70Cuda383
Marysville, O-H-I-O
and FYI, the 4wd trucks are a little different, on page 2-17, it says to install the hub, torque the bolts to 123 ft lbs, and then install the axle nut, and torque it to 173 ft lbs.
