'98 dakota 2wd hub/spindle nut torque spec. ? #374090
07/13/09 04:03 PM
07/13/09 04:03 PM
right between milan dragway & ...
Flite_727 Offline OP
my hub/wheel bearings are toast, anyone know the torque specs. for the spindle nut? i'm on my way out the door now to price the hubs.
thanks-jeff
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: '98 dakota 2wd hub/spindle nut torque spec. ? [Re: Flite_727] #374091
07/13/09 05:41 PM
07/13/09 05:41 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't know off the top of my head, but I have a 98 Dakota FSM at home, I'll look it up when I get home tonight to let you know what the factory calls for...I think it's around 70-80 ft lbs? I don't know...might be more though.
**Photobucket sucks**
Re: '98 dakota 2wd hub/spindle nut torque spec. ? [Re: 70Cuda383] #374092
07/14/09 06:09 AM
07/14/09 06:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Page 2-10 of the FSM calls out for 185 ft lbs for the nut that holds the hub onto the spindle.
whew, that's a lot!
Re: '98 dakota 2wd hub/spindle nut torque spec. ? [Re: 70Cuda383] #374093
07/14/09 06:13 AM
07/14/09 06:13 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
and FYI, the 4wd trucks are a little different, on page 2-17, it says to install the hub, torque the bolts to 123 ft lbs, and then install the axle nut, and torque it to 173 ft lbs.
Re: '98 dakota 2wd hub/spindle nut torque spec. ? [Re: Flite_727] #374094
07/14/09 07:23 AM
07/14/09 07:23 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I replaced one on my '99 Dakota a few years ago...bought one at Advance Auto, found it to be a hunk of junk. I ended up buying one at the dealer and returning the other to Advance.
Re: '98 dakota 2wd hub/spindle nut torque spec. ? [Re: Blues_Cuda] #374095
07/14/09 02:15 PM
07/14/09 02:15 PM
thanks guys!
