What the....?? RB rear main seal from Fel-Pro..
#373906
07/13/09 01:41 PM
07/13/09 01:41 PM
So I got a rebuild kit from Mancini and all was well until I went to put the rear main seal in. It's a Fel-Pro and there doesn't look to be any side seals for the rear main seal cap? Just a couple of funny lookin' pipe cleaner thingy's?
I went to Autozone and ordered the rear main seal by itself on the off chance that the side seals had been left out of the kit. Same deal. Little pipe cleaner thingy's for the sides?!? WTH?
Less than 8 years ago I recall little seals that you glued onto the sides of the aluminum cap that looked like balsa wood.
Am I missing something here??!
Re: What the....?? RB rear main seal from Fel-Pro..
#373907
07/13/09 03:57 PM
07/13/09 03:57 PM
Posts: 25,777 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think the idea is to use RTV in the side seal groves and then push the pipe cleaners in after installation to expand the RTV.
[Re: DaytonaTurbo]
#373909
07/13/09 05:45 PM
07/13/09 05:45 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
That's a no-go now too...Mopar's seal kit comes with the orange "noodles" for the side and they're a SOB to get down so they are flush with the block at the bottom. DAMHIK!! Leak city!! That filling the side gap with RTV is nonsense to me too...pretty messy. I looked eveywhere for the old style ones with the hard side seals, and it appears they're no longer being made.
[Re: superwrench]
#373910
07/14/09 09:58 AM
07/14/09 09:58 AM
I went to Carquest yesterday and they had a rope seal available that had the side seals so I ordered it. We'll see what the side "fillers" look like...
#373911
07/14/09 11:31 AM
07/14/09 11:31 AM
Posts: 2,255 IL
furious70
IL
seen this too, apparently we're supposed to do it like sbc's now.....and like it! Last one I bought was 2 yrs ago (Felpro) and it still had the correct mopar stuff in it.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#373912
07/14/09 11:49 AM
07/14/09 11:49 AM
I just noticed the same thing when I was looking at my gasket set. I thought they left out the rear seal. Mancini sells different rear main seals. They even have the rubber seals for $12.95 it looks like.
#373914
07/14/09 12:40 PM
07/14/09 12:40 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
The so called "NOODLES" do work very well if you have a instruction sheet. The idea is to install them with the seal retainer. The retainer should be clean and dry and the same goes for the side seals. Lubricate the side web of the block with oil on both sides and install with the retainer. The seals will grip the retainer and slide along the block surface as the retainer is placed in the block. Here are some instructions. Never had a leak with these when installed properly.
[Re: Hughes]
#373915
07/14/09 12:42 PM
07/14/09 12:42 PM
This can be a real pain in the butt on these big blocks if you don't do it right the first time.
No doubt! That's why I don't want the crap they're trying to push off on me. We really need to piss and moan at Fel-Pro about this!!
Just went to Carquest and the rope seal kit didn't have anything for the sides despite the picture showing it on the computer!
[Re: roadhazard]
#373917
07/14/09 01:11 PM
07/14/09 01:11 PM
Did you try to install the 1st time like the instructions I posted?
The Fel-Pro units didn't have the orange seals. Fel-Pro includes a tube of goo and 2 pipe cleaners....and because it was in a rebuild kit NO instructions on how or what the pipe cleaners were even used for!
[Re: PC-CHARGER]
#373919
07/14/09 05:09 PM
07/14/09 05:09 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Isn't the BB seal and the slant the same? I read a little about the slant seal need to be oiled or greased if you aren't going to use it right away.
Also read about the RTV on the sides. I haven't started assembling it yet.
My kit isn't Felpro, I think it is Victor.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: MIRADAMANia]
#373924
07/16/09 11:04 AM
07/16/09 11:04 AM
Posts: 916 MB,CAN
PC-CHARGER
MB,CAN
If you are leary of using the new seal/sealant setup you can purchase one of the billet retainers like Mancini sells. They are have two groves machined for "O" ring material. Here's a link to Mancini's offering. http://chucker54.stores.yahoo.net/bilrearmains.html
