harmonic balancer problem
#373689
07/13/09 06:48 AM
07/13/09 06:48 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Last time i took my car out, i had a timing issue, to get it to run right i had to reset it to 22 degrees to make it run right. When i got home i checked my tdc mark and it's 14 degees out. Could the balancer be damaged, has anyone had this happen before and is it clear on inspection. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: harmonic balancer problem
[Re: deaks]
#373691
07/13/09 07:08 AM
07/13/09 07:08 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
A stock balancer the outer ring can slip, so yes, the balance could be bad.
[Re: Bigcube]
#373692
07/13/09 10:40 AM
07/13/09 10:40 AM
deaks
robin hood country
Is it likely to be noticeable. Mick
[Re: deaks]
#373693
07/13/09 10:50 AM
07/13/09 10:50 AM
Posts: 1,178 Indy
FlyFish
Indy
Years ago my stock small block balancer did that. I didn’t notice till I went to shoot the timing and could not find the timing mark with the timing light. After scratching my head a bit wondering what the heck, I noticed an unpainted section on the front of my balancer that was in the shape of my counter weight…the counter weight had spun about 170 degrees. I guess all those nitrous blasts finally tor that stock balancer a new one.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#373694
07/13/09 11:08 AM
07/13/09 11:08 AM
deaks
robin hood country
Has anyone used the 440 source sfi balancer and is it any good. Mick
[Re: deaks]
#373695
07/13/09 11:20 AM
07/13/09 11:20 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
We run the Summit SFI balancers.No problems and mines been on for 10 years.They also have an OE type and a cheaper SFI also.Rocky
Chrysler Firepower
