great start , bad ending #373455
07/12/09 09:36 PM
07/12/09 09:36 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Car realy like the Jet change..ran 7.05-7.05-7.05-7.06-7.07.Air got wrost as we was going along. I like all that..But Jenni come from last run said something wrong.She says I know the E.T not showing it..but it not running right. It got a light miss in it and sounds funny..ok I checking it over..Hey she been in this car a long time so something not right if she says that. I pull all the plugs and valve covers .I can't find anything .Oil pressure is good. so I run it and lisen There is a noise.sounds deep. I don't like this. So I say let go up and stage the car for first round and get our show up points.and I go home take it apart see whats up. so I pull the oil filter off sys-1 full of metal.drain the oil looks bad. I pull the top end off.not the heads can't see anything.pull the Pan all kinds of metal in the pan .But I don't know what it is ? not bearings.So I am looking / thinking..blows my mind ! I don't know what it is..so other look rolling the motor over and I look up and see this. Pam helping me all along..Great woman ! get right out there and helps.
440 source rod pin bushing did't live very well !
Rod bearing look like new..took all 8 of the pin bushings out.
Re: great start , bad ending [Re: VernMotor] #373456
07/12/09 09:38 PM
07/12/09 09:38 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
OUCH. You going to have it fixed for next weekend?
Re: great start , bad ending [Re: VernMotor] #373457
07/12/09 09:40 PM
07/12/09 09:40 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
that sucks
Re: great start , bad ending [Re: VernMotor] #373458
07/12/09 09:48 PM
07/12/09 09:48 PM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
Sorry to see that you had a problem. Pin bushings are a thing that not all engine builders think of.
I really have never seen that happen on an aftermarket rod. Could have been too tight or too loose, could have been just one of those things! Heavy pistons (those are TRW's?), worn pins and excess timing all wear the pins and bushings prematurely.
You should get in touch of 440 Source and see if they have a problem or have seen this. If you find anything out, please let us all know!
Again sorry to see you have a problem. Let me know if we can do anything to get you back on the track.
Good luck!
Jeff Day
Precision Automotive Machine
Canton, Ohio
(330)456-3045
Re: great start , bad ending [Re: VernMotor] #373459
07/13/09 08:06 AM
07/13/09 08:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry to see that Jamie... looks like they didnt have
enough press fit and slid sideways
Re: great start , bad ending [Re: MR_P_BODY] #373460
07/13/09 11:51 AM
07/13/09 11:51 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Doesn't look like the rod around the pin had any excess heat, blue'n etc. The bushing does look thin.
Is that a Mopar or Chevy .990 pin size?
Re: great start , bad ending [Re: Bob_Coomer] #373461
07/13/09 12:09 PM
07/13/09 12:09 PM
NC
440Jim Offline
440Jim  Offline
NC
Jenni has a good ear, and you did a good job digging into the motor to find it. 600 passes is a lot between refreshes, but the rods should not have a problem anywhere near that.
Just thinking out loud. If you have TRW pistons with 1.09" pins, maybe the rod manufacturer just used thinner bushings in the same rod (6.76") used for .990" pins; resulting in a thin bushing. But it does look like it pounded out sideways, not just squished. What stroke, rpm, and piston/pin weight was it?
Re: great start , bad ending [Re: Bob_Coomer] #373462
07/13/09 01:36 PM
07/13/09 01:36 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
1.09 stock size pin
Re: great start , bad ending [Re: 440Jim] #373463
07/13/09 01:39 PM
07/13/09 01:39 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Jim that could very well be.. stock stroke- shift car at 6000 across the line at 6200. old TRW piston..bob-weight was 2532.5g
Re: great start , bad ending [Re: VernMotor] #373464
07/13/09 03:33 PM
07/13/09 03:33 PM
NC
440Jim Offline
440Jim  Offline
NC
That should not be hard on things at all.
Re: great start , bad ending [Re: 440Jim] #373465
07/13/09 05:12 PM
07/13/09 05:12 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I wonder how those rods hold up on a hot street rig?
Re: great start , bad ending [Re: emarine01] #373466
07/13/09 05:45 PM
07/13/09 05:45 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I'd be curious to know what the interference fit was on that bushing.
I would guess it wasn't enough and the bushing slowly worked it's way out.
Re: great start , bad ending [Re: The Shadow] #373467
07/13/09 07:56 PM
07/13/09 07:56 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well here is a flew more pics to lay a eye on.
I took rod-piston apart.
Re: great start , bad ending [Re: VernMotor] #373468
07/13/09 07:59 PM
07/13/09 07:59 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that sucks Jamie, but glad you caught it. oops your drivr caught it
Re: great start , bad ending [Re: Quicktree] #373469
07/13/09 08:06 PM
07/13/09 08:06 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Glad she caught it....better here then traveling all the way to that state up north.
Re: great start , bad ending [Re: Chad Bittle] #373470
07/13/09 08:13 PM
07/13/09 08:13 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
any part of the bushing have a hole to oil the pin? sure look's like the rod was drilled for it, but I see no hole in any of the bushing chunk's that I see, also look's like the rod was rough machined and not honed for a true bushing fit. Sorry about the damage.
Re: great start , bad ending [Re: dartman366] #373471
07/13/09 08:22 PM
07/13/09 08:22 PM
i was looking at the same thing. the real problem is that you should probably re-bush all of the rods. i'd also add holes at 5 and 7 o'clock positions. it looks like you need a new pin also.
Re: great start , bad ending #373472
07/13/09 09:05 PM
07/13/09 09:05 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
No I do not see any hole in bushing..But I will say it seems like there is plenty oil there..and all 8 look just like this..not just one. They all have to be done..Plus new wist pins..they are hurt.
Re: great start , bad ending [Re: VernMotor] #373473
07/13/09 09:17 PM
07/13/09 09:17 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
dumb question here.is there no way to pollish those pins and finish the bushing to fit the pin?i dont know if the bushings come big[thick] enough to acount for the pin size.
forgive my ignorance please.
Re: great start , bad ending [Re: blownzoom440] #373474
07/13/09 09:25 PM
07/13/09 09:25 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Wistpins realy are not much money..in the big picture of this mess..I like to find some lighter pins..these things are heavy..
