non-rallye to rallye cluster Swap E-body #373410
07/12/09 08:36 PM
07/12/09 08:36 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I have a freshly restored rallye cluster that I am going to swap in place of my standard cluster on my 70 Challenger. Any one have any tips or tricks for what I am getting myself into?
Re: non-rallye to rallye cluster Swap E-body [Re: faud88] #373411
07/12/09 08:40 PM
07/12/09 08:40 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Make shure you remember to change your oil sending unit on the engine from the one for a lite to the one for a guage.
Re: non-rallye to rallye cluster Swap E-body [Re: HEMIDOG 70] #373412
07/13/09 11:30 AM
07/13/09 11:30 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
I used a FACTORY service manual with the wiring diagram, that REALLY helped.
I did this swap about 25 years ago, took 3 hours with a helper.
John (Today, it wouild take a whole day, I'm not that sharp anymore!)
Re: non-rallye to rallye cluster Swap E-body [Re: faud88] #373413
07/13/09 12:22 PM
07/13/09 12:22 PM
Gladstone, Michigan
UP FM3challenger Offline
Gladstone, Michigan
if I remember I also had to lengthen 1 wire for a gauge lamp, plus run the wires for the tach. The wiring is the easy part, just remember to remove the steering column bolts so the column can be lowered onto the seat for clearance to remove the cluster.
Re: non-rallye to rallye cluster Swap E-body [Re: faud88] #373414
07/14/09 10:08 PM
07/14/09 10:08 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
btt. thanks!
Re: non-rallye to rallye cluster Swap E-body [Re: faud88] #373415
07/15/09 08:44 AM
07/15/09 08:44 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
How different is the dash harness between the rallye and non rallye??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
