aluminum intake #373359
07/12/09 07:02 PM
07/12/09 07:02 PM
Streetsboro ,Ohio
72duster318 Offline OP
Streetsboro ,Ohio
Probably been asked before but we are installing plugs to fill holes in an Edelbrock intake, do you need to put anything on them, such as RTV or such to prevent a leak? Some are on the area near the radiator hose and have to seal in collant, some would just be in the air area.
Also, I can't remember what I hears a while back, do you torque the bolts 35LBS, same as a steel intake?
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
Re: aluminum intake [Re: 72duster318] #373360
07/12/09 07:03 PM
07/12/09 07:03 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I would use some teflon paste thread sealant, or anti-seize...so if you ever need to get them out, they will not be galled in.
Re: aluminum intake [Re: OzHemi] #373361
07/12/09 07:09 PM
07/12/09 07:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i always use the teflon tape.
Tony
70 AARCuda Vitamin C
Re: aluminum intake [Re: 70AARcuda] #373362
07/12/09 07:37 PM
07/12/09 07:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've just used regular black rtv without problem.
