Re: new leaf springs install (any tips?)
[Re: cudamank]
#373342
07/12/09 07:14 PM
07/12/09 07:14 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
Just dropped the old leafs out from under the car and catching a bite to eat before installing the new leafs. I'm going with the 6 leafs set. I have new bushing and new u bolts. Anything special to watch for? Also does any one know the bolt size on the 8 3/4 third member for mounting a pinon snubber.
Bolts should be 3/8" if you're talking about the snubber plate mounting to the housing.
[Re: Mopar Grandpa]
#373348
07/13/09 12:32 PM
07/13/09 12:32 PM
Posts: 1,216 Fresno, CA
cudamank
Fresno, CA
70 cuda', 69 440 .030 over, 2295f Pistons, 906 heads, 226 int./234 exh.@ .050, 268 int./276 exh adv, 0.494 int./0.513 exh. lift, eddy perfor intake, 750 mech speed demon, 3400 stall, 727.
Interested in opinions on what kind of power it might make, and also how it would do in the quarter.
[Re: cudamank]
#373349
07/13/09 02:04 PM
07/13/09 02:04 PM
Mopar Grandpa
Sebring, Florida
Don't really know but I just had a .030 over 440 engine dynoed on Friday. It has 11.5:1 Ross pistons, Eagle crank & H beam rods, solid lift cam (lost cam card), roller rockers, Mopar high rise single plane intake, 1,000 cfm Holley dbl. pump carb and a set of Indy SR alum. heads and it made 591 h.p. & 590 ft. lbs. of torque. I'm simply guesssing yours will be in the 450-500 range, depending on any work done to the heads, compression ratio, etc. Probably plenty of h.p. for the street but I still don't think 275's will hook up. DOT slick are gonna work better. Have fun with it.
