Is there an ET or mph limit with a stock gas tank? #373106
07/12/09 12:26 PM
07/12/09 12:26 PM
IN
Dartman928 Offline OP
IN
Can't find the NHRA rule book. I wanted to see if there is an et or mph limit when using a stock gas tank.
If anyone has the time to look it up would you please let me know.
This is for an A-Body.
Re: Is there an ET or mph limit with a stock gas tank? [Re: Dartman928] #373107
07/12/09 12:44 PM
07/12/09 12:44 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I do not have the rule book with me but I have read this resently. I am going to say there is no limit for a stock gas tank as long as all the other fuel system rules are followed.
SRT DEMON ONE SEAT
Re: Is there an ET or mph limit with a stock gas tank? [Re: Ron Silva] #373108
07/12/09 05:29 PM
07/12/09 05:29 PM
IN
IN
Thank you....
Tired of having to pop the trunk to put gas in a cell........when its pump gas
Re: Is there an ET or mph limit with a stock gas tank? [Re: Dartman928] #373109
07/12/09 05:45 PM
07/12/09 05:45 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
FWIW, If you have a Dana with an aluminum cover, it will hit the stock gas tank.
Re: Is there an ET or mph limit with a stock gas tank? [Re: Dartman928] #373110
07/12/09 11:31 PM
07/12/09 11:31 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
no ET limit...
Re: Is there an ET or mph limit with a stock gas tank? [Re: Dartman928] #373111
07/13/09 01:00 AM
07/13/09 01:00 AM
i could have sworn the rule back specifically states that when using a stock oem gas tank, the E.T. can NOT be any quicker than the car can actually go and the MPH is limited to exactly half as much as twice as much.
Re: Is there an ET or mph limit with a stock gas tank? #373112
07/13/09 08:47 AM
07/13/09 08:47 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi
your Dart should have an external gas cap, why don't you try this. I have a sender hooked the the stock gas gauge, It's nice not having to open the trunk all the time like you said.
Russ
Re: Is there an ET or mph limit with a stock gas tank? [Re: old_racer] #373113
07/13/09 09:56 AM
07/13/09 09:56 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Hi
Russ
That is slick.
Re: Is there an ET or mph limit with a stock gas tank? [Re: old_racer] #373114
07/13/09 12:10 PM
07/13/09 12:10 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Hi
Russ
Looks great !!!!!!!!
Only problem I can see with it is not knowing when it is full, short of filling till the tube is full. AAlot of times when filling out of a jug it isn't going fast enough to gurgle.
Re: Is there an ET or mph limit with a stock gas tank? [Re: MoparforLife] #373115
07/13/09 01:16 PM
07/13/09 01:16 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi
that's why I put the sender in, it doesn't read the full sweep of the chry gauge but as long as I know where empty is and full is it works great!
Russ
