Re: Engine builders... How much crank end play
[Re: DemonDust]
#373059
07/12/09 11:27 AM
07/12/09 11:27 AM
Posts: 1,880 USA
Ron Silva
USA
Stock Small Block thrust clearance spec is .002 - .007 Max Allowable .010
SRT DEMON ONE SEAT
[Re: DemonDust]
#373060
07/12/09 11:31 AM
07/12/09 11:31 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
My last engine was a Indy Maxx block, that was on the tight side. About .004-.0045 Thats about as tight as I would ever run one, it ran great with no problems. I guess .006-.009 would be idea. BTW How is the work out there? Our hall has very little going on.. Bob J.I.W. Local 769 Ashland Ky
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Hemi Allstate]
#373063
07/12/09 11:47 AM
07/12/09 11:47 AM
Posts: 1,880 USA
Ron Silva
USA
Yes .002 That is what the Factory Service Manual says. So, .002 would be good for a stock 160 horse 318 motor or..........
SRT DEMON ONE SEAT
[Re: Bob_Coomer]
#373064
07/12/09 12:21 PM
07/12/09 12:21 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Very dead here. I worked about 6 weeks this year here and there. My bank acct is def feeling it.
They say it's supposed to get better next year I've been trying to scrape up cash jobs but they are very hard to find as well..
JIW Local 383 Madison WI
[Re: DemonDust]
#373067
07/12/09 12:39 PM
07/12/09 12:39 PM
Posts: 1,880 USA
Ron Silva
USA
Almost any clearance in a motor, MORE would be better.
But just so you know, I ran my 474 CI R3 W9 Motor at .002. It went to .004 after I started it and drove it easy for a few miles and then never got any worse. I would not run a High HP motor at .002 if it is in a Race Car and you are going to lean on it right away.
On the other end of the specrum, the thrust clearance can be quite a bit before anything bad happens. The real limit here is the crank counterweights hitting the block. So if you had a new bearing and the crank thrust surface was good you could easily run it at .010- .012 or even more.
I just took one apart that I was racing the day before and it was .018 with no ill effects (other than me finding copper in the oil filter). You would have never known it.
SRT DEMON ONE SEAT
