gap between heads and valley tray?
#372605
07/11/09 05:34 PM
07/11/09 05:34 PM
Posts: 761 KY
juicedcuda
KY
I am running INDY -1 heads and removable center INDY valley tray. I know you need a bead of RTV on the tray before installing the heads but even with my heads installed, it appears I didnt put enough silicone on the tray. With the gap that is visible, I don't think I should use that much RTV. Can I maybe use clear silicone out of a caulk gun after the heads are installed and just forget about the RTV?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: gap between heads and valley tray?
[Re: J_BODY]
#372608
07/12/09 12:24 AM
07/12/09 12:24 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
This thread may help you make some decisions on your tray. I use Grey RTV just cuz it blends in well with the color of the tray, but the grey is very hard to clean/scrape off, I may use black next time.
[Re: J_BODY]
#372609
07/12/09 01:40 AM
07/12/09 01:40 AM
Posts: 350 Grande Prairie, Alberta, Can.
CW25
Mopar Gray RTV. Used it for years on my "home made" valley pan. Stuff sets up nice.
Yes grey silicone is the [Edited by Moparts - Family Friendly Site - Keep it clean] to use.
