intake manifold torque with alum heads? #372389
07/11/09 01:49 PM
07/11/09 01:49 PM
NC
rickmoore69 Offline OP
NC
What should the torque be for intake manifold bolts with aluminum heads?
Re: intake manifold torque with alum heads? [Re: rickmoore69] #372390
07/11/09 03:51 PM
07/11/09 03:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I dont torque mine but about 25 ft lbs.Rocky
Chrysler Firepower
Re: intake manifold torque with alum heads? [Re: therocks] #372391
07/11/09 04:05 PM
07/11/09 04:05 PM
The torque spec is about getting the proper amt of stretch of the fastener and how much clamping force the gasket needs(for it's type & what it has to contain) assuming the alum threads can hold that amount & yes they can so keep the torque the same(I believe 35)
Re: intake manifold torque with alum heads? [Re: RapidRobert] #372392
07/11/09 05:37 PM
07/11/09 05:37 PM
NC
NC
Thanks for the input guys, I forgot to mention this is a 440 w/ a street dominator intake and stealth heads.
Re: intake manifold torque with alum heads? [Re: rickmoore69] #372393
07/11/09 07:07 PM
07/11/09 07:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
After 40 years I never torque them and Ive installed hundred.Never had a leak.The factory spec is for cast iron not aluminum.Its not needed to 35.Its a non moving part.Rocky
Chrysler Firepower
Re: intake manifold torque with alum heads? [Re: therocks] #372394
07/11/09 10:55 PM
07/11/09 10:55 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: intake manifold torque with alum heads? [Re: rickmoore69] #372395
07/12/09 08:31 AM
07/12/09 08:31 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I also used 25 lbs, may have gotten it directly from an Edelbrock instruction sheet.
