Mini Starter Clearance issue #372342
07/11/09 11:54 AM
07/11/09 11:54 AM
Ft. Wayne In.
Gmg0045 Offline OP
Gmg0045  Offline OP
Ft. Wayne In.
I'm new to this mini starter stuff... Ive been through the archives. I'm having an issue with the main stud on the starter contacting the block on my 440 powered 69 Satellite. Has anybody had a similar issue with this?? There is no adapter on it. I'm thinking I might be able to cut down the length of the stud and then wedge a piece of rubber between it and the block. Any suggestions??
Thanks,
Scott
Re: Mini Starter Clearance issue [Re: Gmg0045] #372343
07/11/09 12:44 PM
07/11/09 12:44 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
What mini starter are you using ? I'm using one from small block Dodge truck on my 440 and it's close to the block but not touching.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Mini Starter Clearance issue [Re: Gmg0045] #372344
07/11/09 01:52 PM
07/11/09 01:52 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
grind the stud down so it's flush with the nut when tightened, also grind a small notch on the block above the stud
Re: Mini Starter Clearance issue [Re: nss guy] #372345
07/11/09 01:55 PM
07/11/09 01:55 PM
PA
moparacer Offline
moparacer  Offline
PA
Mine had a extension piece on it and it was fine when I had it on small blocks but I had to take it off when I went to the big block,,,,
just unbolted it and bolted the wire on the stud that goes in the housing.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Mini Starter Clearance issue [Re: nss guy] #372346
07/11/09 01:59 PM
07/11/09 01:59 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
did the same here less the block grind.
Re: Mini Starter Clearance issue [Re: Gmg0045] #372347
07/11/09 04:09 PM
07/11/09 04:09 PM
Ft. Wayne In.
Gmg0045 Offline OP
Gmg0045  Offline OP
Ft. Wayne In.
I went the a boneyard (Oops) I mean Auto recycler and asked for a starter for a 97 Dodge Ram with a 360. I'll try the grind down the stud trick. I'm just a little scared of the stud being that close to the block and accidently burning down my Hotrod!! Thanks for the replies!!
Scott
Re: Mini Starter Clearance issue [Re: Gmg0045] #372348
07/11/09 06:21 PM
07/11/09 06:21 PM
Ft. Wayne In.
Gmg0045 Offline OP
Gmg0045  Offline OP
Ft. Wayne In.
I went out and cut off the excess bolt. I now have about 1/16 to 1/8" clearance to the block. I'll wedge a peiece of rubber in there when I tighten it down. That should do it !! Thanks again for the help.
