Mopar Metallic Core Plug Wire??? #372302
07/11/09 11:13 AM
07/11/09 11:13 AM
Fremont,Ca.
MarcusEdell Offline OP
Fremont,Ca.
Are these wires to be used with Electronic Igntion like Mallry Unilites?
Re: Mopar Metallic Core Plug Wire??? [Re: MarcusEdell] #372303
07/11/09 06:44 PM
07/11/09 06:44 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i'm not sure about the wires in question. judging by the word metallic in the description i "assume" they're solid core wires. if that is the case then i say no. as a general rule suppression type wires should be used with any car that has electronics in it.
Re: Mopar Metallic Core Plug Wire??? [Re: jamesc] #372304
07/12/09 11:12 PM
07/12/09 11:12 PM
Fremont,Ca.
Fremont,Ca.
Thats what I was afraid of..Thanks
Re: Mopar Metallic Core Plug Wire??? [Re: MarcusEdell] #372305
07/13/09 02:39 AM
07/13/09 02:39 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
A great deal on some great wires -- check out Summits 50 ohm per foot wires . They are around $69 last time i checked.
Mine work great !
edit =
here ya go :
http://www.summitracing.com/parts/SUM-881000/
