Running out of motor?
#372230
07/11/09 07:47 AM
07/11/09 07:47 AM
Posts: 1,776 Keymar, MD
DusterKid
Keymar, MD
I broke a piston in my motor 2 wks ago and ruined it. It was a basic 440, stock bore, pistons, closed chambered iron heads with larger valves with a .533 mopar performance purple camshaft. (rated 3600-6300 rpm) It would 60ft 1.54-1.56 and run high 7.1s to mid 7.2s @ 93 mph in the 1/8th mile and I'd shift at 6000. I put my backup motor in which is 30 over, scat rods, 440 source alum heads, lunati voodoo .533/552 camshaft, (2500-6500) it leaves like a bear 1.48-1.49 60ft, but it feels like it runs out of motor at 5800 rpm and only went a 7.03 @ 95mph. I let everything else alone, and then started jetting the carb up to see if that would help and it really didn't and plugs look fine. The carb is a 750 holley dp, wieland alum intake, converter is a 5000 stall. I'm thinking maybe the cam has something to do with it stalling out, but not really sure, anyone have any thoughts on what maybe causing this?
Re: Running out of motor?
[Re: KMPX2]
#372233
07/11/09 09:03 AM
07/11/09 09:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm thinking carb but also if you cant get the shift point higher you have too much converter.... stall should be near your peak torque but about 1500 below the shift. Did you degree the cam in, whats the installed degree and what is the LSA
[Re: Dodgem]
#372238
07/12/09 11:19 AM
07/12/09 11:19 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
My kid has the same problem.We put my reworked 516s with bigger valves on his 62 300.The Hughes cam is too small.He runs out of power at like 5600.It is consistenet though at 13.7s.It was running at 13.7 to 13.8 before with the tiny heads that were stock.Still not bad for a 4200 pound car that still has all the OE lower end.Thinking about the Lunati Voodoo cam for it now.Rocky
Chrysler Firepower
