How do you tell if the "power valve" is bad?? #371747
07/10/09 02:55 PM
07/10/09 02:55 PM
Murrayville, Illinois, usa
scotts66charger Offline OP
Running a .30 over, 440. Has a 750 Holley DP. How can I tell if the power valve is bad?
Re: How do you tell if the "power valve" is bad?? [Re: scotts66charger] #371748
07/10/09 02:58 PM
07/10/09 02:58 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
They don't go bad as often as people say. How old is your Holley carb, btw? After 92 or something, they all had the check valves.
edit: to tell if it's bad, take it out, and suck on the large end. No, I'm not kidding. If you can move the sprung piece toward you, it's still good.
Re: How do you tell if the "power valve" is bad?? [Re: sharpie] #371749
07/10/09 05:46 PM
07/10/09 05:46 PM
Well, yeah, they do. Or at least they used to. I used to rebuild Holleys "moonlight" while I was at Miramar. I've been into at least a hundred. I'd be I've found at least 5 bad power valves RIGHT OUT OF A NEW KIT.
So far a sucking on the valve, you cannot tell if it's leaking, which is what causes the problem. Another thing that causes them to "be" bad is overtightening, which warps the thing
The BEST way to tell is that a previously tuned car simply will not idle, and the idle screws have little effect. When I was doing this moonlight rebuilding, I used to mark and save valves that I knew had been OK on idle. The acid test is simple. replace with a a good valve.
Re: How do you tell if the "power valve" is bad?? #371750
07/10/09 06:03 PM
07/10/09 06:03 PM
Az
Crizila Offline
Crizila  Offline
Az
I made an adapter fron an old spark plug boot that I use with my Mighty-Vac. I can not only tell if they leak, but I can also see at what vacuum they actually start to open and compare it to what is stamped on the valve.
Fastest 300
Re: How do you tell if the "power valve" is bad?? [Re: Crizila] #371751
07/10/09 06:37 PM
07/10/09 06:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some Mighy-Vacs come with a suction cup attachment that will fit over the end of a power valve.
