Re: New Paint job on a budget thread.
[Re: Roadster_wa]
#37154
07/22/07 07:43 AM
07/22/07 07:43 AM
Posts: 49 Maine
Blackstone
Maine
These ripples are killing me!!! Roll and tip method may be going out the door. I simply cannot get rid of the ripples until I've sanded to my original paint. I guess I've just got to muster up enough patience to let the thousands of bubbles pop on their own. How do I overcome the fear that they won't pop? Thin, thin, thin, right? I'm having trouble capturing the ripples with my camera, but here's an example of where I'm at after a round of 2000 and turtle polish (by hand for now): ![](http://img.photobucket.com/albums/v432/tibz/100_2454.jpg) I'm going to knock the ripples down some with 600, then try 2 more super-thin coats this morning. We'll see what happens.
[Re: Roadster_wa]
#37155
07/22/07 08:54 AM
07/22/07 08:54 AM
Posts: 571 central PA
mopartial
central PA
Anybody try this with SS (OMNI) auto paint? It is enamel, dries quick and its already mighty thin.
I have it already in orig color but dread spraying whole car. I could do PJOAB but dont want a color change...
Who mixes custom color Pro Rustoleum?
If it aint broke, dont break it.
[Re: Blackstone]
#37156
07/22/07 11:14 AM
07/22/07 11:14 AM
Posts: 49 Maine
Blackstone
Maine
Okay, regarding ripples... Since it worked for Charger, I've been wetsanding by hand without a rubber/foam block for the most part. I wasn't comfortable with the "suction" effect from my rubber block, but I've found that it's the only way to effectively knock down the ripples without sanding through all 6-8 layers I've now rolled. By using my hands, I was merely widening the valleys, in the process making them deeper. The firm rubber block on the other hand, applies most of it's force to the peaks, eventually working the surface to a level state. What it boils down to is... Would I rather sand ripples or orange peel? We'll find out tonight which is easier. While I've found the ripple remedy, I decided to apply a 25% thinned coat, then pop the bubbles with light pressure with the roller as prescribed in the very beginnings of the "Paint Job On A Budget" thread. These pictures are only 1 hour after rolling. I can see that I'll be dealing with significant orange peel, but this paint has proven to have good leveling qualities. ![](http://img.photobucket.com/albums/v432/tibz/th_100_2457.jpg) ![](http://img.photobucket.com/albums/v432/tibz/th_100_2455.jpg)
[Re: Blackstone]
#37157
07/22/07 12:23 PM
07/22/07 12:23 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Way back... probably in message thread one of this epic I shared with everyone what I used to back my sandpaper when wet sanding. I thought I would again tell the tale because it worked for me and proved to be exceptional for the wetsanding task. I took one of my wife's high density foam knee pads that she uses in the garden to protect her knees when working in the garden The foam pad is about.. 15 x 18 x 3/4 inch... At around $ 3.00 to $ 5.00 ( so it is a bargain ). And what you do is take your scissors or exacto knife and slice off a section that is handsize and tailored to fit a half page of sand paper. You simply wrap the sandpaper around the foam block, dip it in the water/soap bucket and it tends to hold together nicely as you use it to work the cars body surface with your wet sanding. Here is a supplier on eBay that is selling them for $3.00 - $ 5.00 IF you cannot find any at your local garden supply stores.. http://cgi.ebay.ca/Gardening-Knee-Pad-LA...1QQcmdZViewItem The key feature of this high density foam is that it holds its shape, keeps surfacing level, it feels great in the hand, you can tailor the size of the sanding block to whatever YOU want and feel most comfortable with. And best of all... for 3 bucks you can make a number of sanding blocks out of the one foam slab. Nuff said. Hope this helps some folks out.. and once again proves that we can use things designed for one purpose for a totally different purpose than it was intended. Thinking outside the box saves money... ![](/ubbthreads/images/graemlins/wink.gif) And in case you are wondering... YES.. my wife was mucho annoyed when she saw what I had done to her gardening pad hahahhahhahh... c'est la vie.. Marq .
[Re: Marq]
#37158
07/22/07 01:10 PM
07/22/07 01:10 PM
"Honey have you seen my knee-pad?" "Um, well here's the thing. I caught the dog chewing on it, and it was a mess. Why don't you buy yourself a new knee-saver?" I used a kitchen sponge I found under the kitchen sink that I am pretty sure my wife didn't need, and it worked much better than sandpaper alone.
I think I have settled on about 50/50 for mineral spirits and paint mixture. I know now I had it way too thick which is what caused some earlier issues(see picture).
#37159
07/22/07 01:57 PM
07/22/07 01:57 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
The problem with most of the kitchen sponges that I know of is that they aren't very dense. So they don't tend to hold a firm level surface when mated up with a wet piece of sandpaper. So instead of cutting the caps off the ridges, it tends to allow the sandpaper to flex into the valleys as well as the caps. The other downside to most kitchen sponges is that they are made out of some crappy synthetic stuff that tends to flake particles off the sponge the longer they are used. Then again... even 100% natural sponges also tend to fall apart when put into situations where there is abrasion going on.
That was another good feature of those gardening knee pad foams... is that because they are high density foam.. they don't tend to disintegrate with water or abrasion. And they always tend to rebound back to their original shape. I think they call that ability a 'memory' in materials.
And I should mention that this type of 'high density foam' is like 10 or 20 times more dense than the 'high density' foam rollers that we use. I thought I would mention that in case there was any confusion about the definition of high density foam when comparing the rollers versus these knee pad thingys..
[Re: Blackstone]
#37161
07/22/07 09:51 PM
07/22/07 09:51 PM
This is my first post! whooo! anyways, I hope to join you guys very soon, and plan on painting my celica (im not even a car guy, but I want to repaint the car and practice using bondo on a small dent..) I'll be driving the car on the off days between coats.. anyways! I've read through the first entire thread and partly through the second but it's hard to keep up with all the information.
1. What is the general opinion on what paint to use now? Rustoleum or Brightside?
2. Odor , or odorless Mineral spirits?
3. If possible, is it advisable to use a sprayer instead of a roller?
The rest I've read through about the technique and how to do everything, seems simple enough. If anyone can answer the above two questions I'd really appreciate it. I have down how to avoid the orange peel effecets, and any other defects that may occur, I just want to be up to date on the new products.
#37162
07/22/07 11:09 PM
07/22/07 11:09 PM
Has anyone used rustoleum charcoal gray??Ill be trying it on a 67 cougar soon.
[Re: 69chargeryeehaa]
#37164
07/23/07 12:34 PM
07/23/07 12:34 PM
WOW,,,,WHAT A FANTASTIC LOOKING CAR. DO YOU HAVE ANY BEFORE PICS?
[Re: Blackstone]
#37166
07/23/07 04:17 PM
07/23/07 04:17 PM
Well I have to admit, I'm not exactly thrilled with my polishing skills. After the third coat, I gave it another once over with 1000 grit, hand polished with some turtle wax polishing compound and finished it off with carnauba wax. The beautiful gloss of the paint after the third coat is gone, replaced by an endless haze of swirl marks. Go me! So until I can get some kind of power tool or work on my skills, I'll paint the rest of the car and leave the polishing for another time. The paint itself is incredibly smooth to the touch. Theres no ridges, no orange peel, not even a hit of brush marks. Just a bunch of hazy swirl marks. I either figure out a better way to polish this panel or just give it a 4th thin coat. Its good to know I can fix it. You can almost see the swirl marks around the reflection of the sun. ![](http://farm2.static.flickr.com/1198/878440144_e57b26a327_o.jpg) Before polishing ![](http://farm2.static.flickr.com/1147/868383856_af495ac296_b.jpg) After ![](http://farm2.static.flickr.com/1092/878440256_8f5995bd00_o.jpg) Not exactly mirror finish anymore. ![](http://farm2.static.flickr.com/1243/877591819_d62b2834fb_o.jpg)
[Re: Marq]
#37168
07/23/07 05:09 PM
07/23/07 05:09 PM
Marq Wrote:- "One nice thing about Brightside is that Interlux, the manufacturer, does have global distribution. So it should be locatable anywhere in the world. It's odd that you are encountering difficulty locating a distributor within Poland." Just wanted to say you were right about the Interlux being available. Every other avenue of enquiry proved fruitless, but the guy in Poland came through today with 4 x 750 ml of Brightside Balck Gloss, it'll be with me by the weekend .... then the fun starts. I've a question about spraying. I picked up on this product from an Australian car forum where a guy was saying he'd had fantastic results using it spraying his car. Here's the URL http://www.prevalspraygun.com/home.htm Again, none here in Poland but if it seems a good product, (and I've not a clue as I just saw it today), then I might use it for door jams and the engine bay etc. I can buy them in the UK. And if it looks viable for Brightside how much would you guess I'd need to thin the paint? Thanks.
#37169
07/23/07 05:27 PM
07/23/07 05:27 PM
Posts: 2,419 Massachusetts
Faust
Massachusetts
Marq Wrote:- I've a question about spraying. I picked up on this product from an Australian car forum where a guy was saying he'd had fantastic results using it spraying his car. Here's the URL
No real experince with them, but Preval units are everywhere here in America. The price is down to about $5.00 each. 4-5 years ago, they were about $13.00.
[Re: Faust]
#37170
07/23/07 05:51 PM
07/23/07 05:51 PM
The price figures as they are £5.50 ($11) in the UK, the Brits mostly just swop the $ sign for the £ sign. I just thought they looked a convenient and simple way to apply a paint in a spray form. If anyone has used them and found they just don't do the job that well it would save me the bother of another purchase from the UK. A handy accessory though, I can think of a lot of uses for this thing. Cheers.
#37171
07/23/07 05:53 PM
07/23/07 05:53 PM
tjts1 - it's allmost not possible to get the shine a power polisher will do in 5 mins by hand. With that said, get a polisher, you'd be amazed at how fast they bring that shine back. Otherwise your skills look great as far as painting goes, that's the hardest part to get down pat, the polishing I find is the easy part.
Thanks! I'm kind of surprised that I was able to get away with just 3 coats thinned out with 2 parts paint, 1 part mineral spirits. The sunroof was a test panel that I'll eventually put on the car but I think by the third coat I finally got the hang of not over brushing the paint to get rid of the bubbles. I get better results brushing over the paint extremely lightly and slowly as opposed to hard and fast. I'm just using the weight of the brush itself to pop the bubbles.
[Re: Blackstone]
#37173
07/23/07 07:45 PM
07/23/07 07:45 PM
mopartial
central PA
My 75 plymouth is a deep maroon, I think called Rallye Red. Pro Rustoleum Regal Red:Royal Blue::2:1 looks nearly dead on...Count me in on PJOAB!
