Holley float ? #371308
07/09/09 07:44 PM
07/09/09 07:44 PM
Canada
N
NiceFishEh Offline OP
N
Canada
Both of my floats are low on my 650 Holley Vac Sec.
I can't get fuel to dribble out the sight plugs, as I've read everywhere.
With the the 340 warmed up and running,I loosen the lock screw, then turn the nut ccw to raise the float.
Nothing happens.
Why?
Re: Holley float ? [Re: NiceFishEh] #371309
07/09/09 07:51 PM
07/09/09 07:51 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
try turning it the other way
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Holley float ? [Re: NiceFishEh] #371310
07/09/09 07:52 PM
07/09/09 07:52 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Take the bowls off, turn them upside down and see what is keeping the floats from raising.
You can baseline them before reinstalling, with the bowl still inverted adjust so the top of the float is level/paralell with the top of the bowl.
Re: Holley float ? [Re: NiceFishEh] #371311
07/09/09 08:42 PM
07/09/09 08:42 PM
Nothing happens. Why?
They are left hand threads. Turn it CCW & if no luck as b5 bee said open her up & see what ain't right
Re: Holley float ? [Re: RapidRobert] #371312
07/09/09 08:56 PM
07/09/09 08:56 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Its very easy to screw the needle & seat assembly so far in that the flat in the nut no longer engage it. The nut then turns and nothing else.
Take the screw off, remove the nut and then the gasket. Then put the nut back on with no gasket and unscrew the needle assembly out a turn or two and re assemble it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Holley float ? [Re: CJK440] #371313
07/12/09 06:36 AM
07/12/09 06:36 AM
Canada
N
N
Canada
This is exactly what happened. The square sides of the needle valve actually chewed into the square sides of the nut, and caused the slip. Can't believe that the brass needle is harder than the nut material. Com'on Holley!
Thanks guys.
