Re: Holley float ?
[Re: NiceFishEh]
#371309
07/09/09 07:51 PM
07/09/09 07:51 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
try turning it the other way
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
Re: Holley float ?
[Re: RapidRobert]
#371312
07/09/09 08:56 PM
07/09/09 08:56 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Its very easy to screw the needle & seat assembly so far in that the flat in the nut no longer engage it. The nut then turns and nothing else.
Take the screw off, remove the nut and then the gasket. Then put the nut back on with no gasket and unscrew the needle assembly out a turn or two and re assemble it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Holley float ?
[Re: CJK440]
#371313
07/12/09 06:36 AM
07/12/09 06:36 AM
Posts: 7 Canada
NiceFishEh
Canada
This is exactly what happened. The square sides of the needle valve actually chewed into the square sides of the nut, and caused the slip. Can't believe that the brass needle is harder than the nut material. Com'on Holley!
Thanks guys.
