Pertronix
#371011
07/09/09 02:58 PM
07/09/09 02:58 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
Has anyone had good luck with the Pertronix setup that supposidly eliminates points with a Hall Effect type sensor? I know they sell these for about $70 for Mopar big block single point dizzies.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Pertronix
[Re: MoparJ]
#371013
07/09/09 03:02 PM
07/09/09 03:02 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I think Stu (MidPenMopar) changed recently (Last year) been having problems with another brand but has not a comlaint about the pertronics yet.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: Pertronix
[Re: Classof70Chally]
#371016
07/09/09 03:19 PM
07/09/09 03:19 PM
Posts: 15,487 Florida
scratchnfotraction
I run a points dizzy and pertronix points conversion with the 40,000 volt flame thrower coil thats for it,been 9 yrs never skiped a beat yet dont use nothing but a pertronix rotor,others fit and will work but the are not right,sloppy fit I put one on every mopar I get,first thing is loose the stock crap fixin to use a points dizzy and a conversion on the 440 truck i am a buildin up
Re: Pertronix
[Re: Andrewh]
#371018
07/09/09 04:49 PM
07/09/09 04:49 PM
MoparJ
Simi Valley, CA
Would you suggest bumping the timing a few degrees towards the advance side after install of this?
Re: Pertronix
[Re: MoparJ]
#371019
07/09/09 04:59 PM
07/09/09 04:59 PM
scratchnfotraction
dont see why not as long as it does not ping run as much as it will take cheap gas I back off on the timming,but with good gas I bump it up to about 14* BTDC cheap gas I back down to 10* and cruz just barly pings on 93 gas hard on the wot blast mine is a high milage stock 360 headed 318 with a 60710 voodoo roller cam,LD4B intake 600 carb headers,stock hs lock up a999,8 3/4-3.23 gear,29x15x15 M/Ts gets about 18-19 mpgs under 60mph in a 85 stepside
Re: Pertronix
[Re: scratchnfotraction]
#371020
07/09/09 05:07 PM
07/09/09 05:07 PM
MoparJ
Simi Valley, CA
dont see why not
Its going onto a 383 in a 66 Charger with stock compression, Hooker headers, 2.5" piping with H pipe, Edelbrock performer intake and 650 Holley double pumper.
Re: Pertronix
[Re: drmonday]
#371024
07/09/09 06:32 PM
07/09/09 06:32 PM
Posts: 18,157 Mass
DAYCLONA
Mass
It's all I'll ever run,.....just be sure to buy the Flamethrower coil, the ohm rating is different, eliminate the ballast resistor, follow the instructions,....and if you go with either Pertronix I or II, (I'd recommend II) conversion kit, do not remove the green looking "Tape" on the rotor magnet, and do not use a metal feeler gage to set the air gap, a plastic gage is supplied,.....I'd recommend you purchase a new/rebuilt distributor for your conversion, as the HallCell is sensitive to "sloppy" tolerances in the dist shaft, a worn shaft/bushings will shorten/destroy the life of the HallCell, and cause irratic ignition woes,.......you will see an increased starting ability, and cleaner, longer use of dist caps, plugs, as long as you upgrade all your componets at the same time,....Pertronix also has plug wires avaliabl in black for mopar applications,....also do not run solid core racing wires, as this WILL destroy the HallCell
