Re: Rallye Dash Conversion
[Re: Hawg_Man]
#370722
07/09/09 02:08 PM
07/09/09 02:08 PM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
You can use your existing harness fairly easily if you have the wiring diagram from the FSM. Cut the existing round connector off the existing harness and lengthen/terminate the wires as necessary. The wire colors in your harness will match the FSM. You may have to untape the headlight switch connector and/or the wiper switch connector from the harness to get it to reach, but there should be enough slack that they will reach.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
[Re: IMGTX]
#370724
07/10/09 02:32 AM
07/10/09 02:32 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
as stated, yes there are differences, but can be done.
Another diff is rallye cluster gets power in ACC and RUN for a while Standart cluster gets power just in RUN.
Try get a 74 ( specifically 74 due the interlock only 74 stuff ) rallye harness will make LOT EASIER and they are not that hard or expensive to get. I got it and made the conversion and I'm outside USA ( got on ebay USA )
