904 trans #370664
07/09/09 02:57 AM
07/09/09 02:57 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
h i have a 3550 lbs indy headed small block 580 hp going to give her 200 shot ,904 is reco stock box with trans brake vb full manual 1.55 60 ft will this handle the gas of the line?
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: 904 trans [Re: Ian] #370665
07/09/09 06:57 AM
07/09/09 06:57 AM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
We have been running 904's several years, in both our cars, 3000 lb. Dart avg., 1.34 60' time transbrake, in a bracket race mode with lots of passes, with nothing more than clutch wear. Our Cuda broke an output shaft once in the middle of a wheelstand, but it was 3700 lbs and 1.40 60' times footbrake, but your dealing with 30 year old parts and your putting 2-3 times more torque to it than the chrysler engineers ever dreamed.
Re: 904 trans [Re: Ian] #370666
07/09/09 12:14 PM
07/09/09 12:14 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
My Demon w/904, 3175 pounds on the footbrake with 650HP 474CI R3 W9 Small Block broke the output shaft on a launch. Never had a problem until I put a 3.55 gear (28" tall tires) in the rearend and that put too much load on the trans.
SRT DEMON ONE SEAT
Re: 904 trans [Re: Ron Silva] #370667
07/09/09 01:04 PM
07/09/09 01:04 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thank for the info sounds like the chances are small that it might break ,so i will give it ago ,will be racing on the 19 th so i will let use know how it goes.
Re: 904 trans [Re: Ian] #370668
07/09/09 06:55 PM
07/09/09 06:55 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
BTT
Who else here has experience going fast with a 904?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: 904 trans [Re: topfueldart] #370669
07/09/09 07:06 PM
07/09/09 07:06 PM
CT
turbocolt2.4L Offline
CT
how fast is fast? i ran 9.51 with 1.40 short time 2500lbs car leaving 6000rpm on 2-step 27psi of boost.
Re: 904 trans [Re: topfueldart] #370670
07/09/09 07:11 PM
07/09/09 07:11 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Light weight tube chassis car, low 9's, 145 MPH, 1.23 60. Had a Griner brake. Never broke it, but you have to do some maintenance. Super Stock Hemi cars use 904 components in a 727 case. It can be done, but you have to use the right stuff. Don't expect a $500 trans to stay in the car all year.
Re: 904 trans [Re: CMcAllister] #370671
07/09/09 07:31 PM
07/09/09 07:31 PM
mid Ga.
W5Dart378 Offline
W5Dart378  Offline
mid Ga.
If it has aluminiun planitaries in it, the splines on it wont last too long. I've broke every piece of the drive line in mine.(since the new converter)
I will also say if you have a converter that slips a lot it will help the trans live..
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: 904 trans [Re: topfueldart] #370672
07/09/09 08:05 PM
07/09/09 08:05 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
One of my coustomers is running an 85 short bed fullsize pup that I built a pretty strong 340 with E-Brock heads that runs 12.30s. no problems reported with the 904 trans. he has also put a little no2 through the motor. He also runs an 8.25 rear (4.30 gears) also holding up.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
