Fan controller?
#370645
07/09/09 12:57 AM
07/09/09 12:57 AM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
What thermostatic fan controller are you using? I need something to run with an HHR fan assy and Griffin crossflow rad. Thanks!
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
Re: Fan controller?
[Re: Fishmarket]
#370647
07/09/09 07:35 AM
07/09/09 07:35 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Spahl makes a nice one with some cool features or you can pick a standard one from Summit.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Fan controller?
[Re: Dragula]
#370650
07/10/09 12:19 PM
07/10/09 12:19 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I use the Moroso temperature switch. I plumped it into my water line.
Re: Fan controller?
[Re: Quicktree]
#370652
07/10/09 12:38 PM
07/10/09 12:38 PM
Posts: 2,567 Appalachia
RedRam
Appalachia
The controller that came with my flex a lite black magic extreme fan was JUNK. Worked ok at first, but then it got to where even the slightest bit of moisture in the air would cause it to turn on and not shut off. Got to where I had to pull the fuse at night because the dew/fog would turn on the fan at sometime during the night Now I use a manual controlled relay to turn it on/off.
