Questions about Edelbrock heads for Small - Block. #370485
07/08/09 10:19 PM
07/08/09 10:19 PM
SK. Canada
Not_A_Duster Offline OP
SK. Canada
Hi folks
Been a long time since I've been here.
I figure if I stay away from the circus on the general board, it should be OK....
Gotta a couple questions regarding Eddy heads (the closed chamber variety.)
Rated chamber size is 63 cc. How does this compare to stock '72 - 74 360 as far as chamber volume is concerned? is there a compression gain to be had by using the Eddy's?
Also - it says in the brochures and online that adjustable rockers or pushrods must be used. Why is this? It would seem to me that if a streetable hydraulic cam is used, this should not be neccessary. Or am I missing something?
Thanks in advance.
Bruce Lozinsky
....evil is winning....
Re: Questions about Edelbrock heads for Small - Block. [Re: Not_A_Duster] #370486
07/08/09 10:47 PM
07/08/09 10:47 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
If I remember most 340-360 heads were in the 63-65ish CC range but I've CC'd them with a little more so not much if any gain there. As for requiring adjustable rockers I guess I never noticed on the LA ones. I know they are required on the Magnum ones...
Re: Questions about Edelbrock heads for Small - Block. [Re: Dusted_Ya] #370487
07/08/09 11:24 PM
07/08/09 11:24 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
unmilled 340-360 heads are somewhere around 72 cc...you should gain around one full compression point..
you can use non adjustable rocker arms and stock pushrods...
only problem is the stock rockers with the incresase spring pressure from the eddy might punch holes thru the rockers...
Tony
70 AARCuda Vitamin C
Re: Questions about Edelbrock heads for Small - Block. [Re: Not_A_Duster] #370488
07/08/09 11:25 PM
07/08/09 11:25 PM
NY usa
540challenger Offline
NY usa
Stock 340/360 heads cc around 70-72cc
You should ssee about a point increase in compression.
The magnum heads needs adjustable hardware b/c it uses a cehvy style rocker not a stock mopar rocker "magnum do come 1.6 ratio on rockers from the factory"
You might get away with the stock style pushrods ands rockers on the LA versions but you need to double check this away don't just bolt on the heads a assume it is right.
Re: Questions about Edelbrock heads for Small - Block. [Re: 540challenger] #370489
07/08/09 11:27 PM
07/08/09 11:27 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
just finished a few minutes ago installing rockers on eddy magnum heads...what a pain in the azz.....
Tony
Re: Questions about Edelbrock heads for Small - Block. [Re: 70AARcuda] #370490
07/08/09 11:33 PM
07/08/09 11:33 PM
NY usa
NY usa
What gave you trouble pushrod clearance???
Re: Questions about Edelbrock heads for Small - Block. [Re: 540challenger] #370491
07/08/09 11:38 PM
07/08/09 11:38 PM
SK. Canada
SK. Canada
Thanks everybody.
Didn't even consider the spring pressure - good point. Seems obvious now when I think of it.
It's the LA heads I'm looking at -
Re: Questions about Edelbrock heads for Small - Block. [Re: 540challenger] #370492
07/08/09 11:40 PM
07/08/09 11:40 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
no..i am using a solid lifter cam, i bought an adjustable pushrod to measure the correct length..
ordered them and got them today,
problem was the rockers were not lining up with the valve tips...had to loosen the guide plates and align the tips...then retighten studs..
i guess this is my first experience with sb chevy (studs)...can not believe they just hang out in the air (cantilevered)
Tony
Re: Questions about Edelbrock heads for Small - Block. [Re: 70AARcuda] #370493
07/08/09 11:50 PM
07/08/09 11:50 PM
That takes a different mindset doesn't it . thanks for the heads up on the general board mentality as I was considering going over there for a change of pace
Re: Questions about Edelbrock heads for Small - Block. [Re: 70AARcuda] #370494
07/09/09 07:44 AM
07/09/09 07:44 AM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
fun Eh!
as a recommendation to improve air flow - do some blending/rounding of the knife edge at the top of the plenum inlet.
also, check pushrod clearance thru the head, especially the intakes.
